HELP striped the nut on turbo exhaust outlet!! shit!
HELP striped the nut on turbo exhaust outlet!! ****!
**** i just found out the greddy kit i bought was fucked, the guy before putting the kit together striped the stub on the turbo exhaust outlet. those 4 holes.. he striped 2 of the bolts on them and he cut them off, now the stub is stuck on there with loctite or some kind of sealant. **** what can i do to fix it? (i was thinking bout drilling it out..really no other choice) will i have problems in the future ?? wuts the best way of going to fix this? thanks for all the help
Re: HELP striped the nut on turbo exhaust outlet!! ****! (tbkonwso)
Which holes are they stuck in (I can't see in the pic, they all look good to me).
I would suggest drilling them out, yes. Definetly cover up that housing though, don't want any particles in there w/ those fins. Drill them out, and then put bolts/lockwashers/nuts in there to hold it together. Either that or stick a bolt in ther and locktite/epoxy them in and hope you never have take it apart again
jB
jB
Re: HELP striped the nut on turbo exhaust outlet!! ****! (PeloTudo AKA Gringo)
its not in the picture, im just using that as an example yea im gona try to drill it out.. than lock that **** hopefuly.. nothing leaks or breaks. after i put it together.
Re: HELP striped the nut on turbo exhaust outlet!! ****! (TurboInteg95)
Try a sharp flat head screwdriver and hammer, worked for me on my stripped exhaust manifold nuts.
1epmugenlude
08-01-2005 07:21 PM
