doing track burnouts in second gear?????
Old Sep 19, 2002 | 02:42 PM
turboex's Avatar
Default doing track burnouts in second gear?????
OK when i got\ to the track i always heat up my drag radials with a about 7-10 secs of first gear. however i have been reading that first gear is not enought to heat up tires to there full use. any ideas on this guys? what do you guys do? also i have always been scared of breaking an axle if i do a burn out in second. is this realy an issue? thanks
[Modified by turboex, 11:42 PM 9/19/2002]
Old Sep 19, 2002 | 02:52 PM
fast[R]'s Avatar
Default Re: doing track burnouts in second gear????? (turboex)
Yes if you realy want them hot second gear. You wil not breack a shaft on the burn out stay on the water and you wil be fine
Old Sep 19, 2002 | 03:34 PM
DIRep972's Avatar
Smarter than you
2nd gear is the only way to heat em up right. i do a quick spin in the water to get em wet. once they are wet they spin easier and i pull out of the water box, put it in 2nd and drop it at 6500. basically i just heat them till i see smoke coming into the cabin. turn the wheel back an forth to get the whole tire hot. w/ BFG's and a burn out like this, u can hit 2.0 60fts with ur legs being asleep.
Old Sep 19, 2002 | 04:04 PM
turboex's Avatar
Default Re: doing track burnouts in second gear????? (DIRep972)
sweet, well i have a set of bfg older drag radial (the say "Comp TA Drag Radial" on the side and a set of nitto 555r's. The bfgs are 225/45/14 on a 6 1/2 inch rim. the nittos are brand new and almost the same total size of my 17's. what ones should i race on? reason im so worried about this is its the last time the track will be open this year up here. Also with the second gear burn out, do you stay in the water or just ride threw it and then burn the tires? Also my best 6ft's to date ins a 2.5. so i gotta get better than that. thanks guys
Old Sep 19, 2002 | 04:33 PM
Smashback's Avatar
Default Re: doing track burnouts in second gear????? (C5_ALLMOTOR)
I won ugliest NAWZ equipped VW for my white car with graphics all over it. That was at Drag Wars in the desert. Got beat by an S2000 though. I pushed the nitro button too soon.
Old Sep 19, 2002 | 05:05 PM
turboex's Avatar
Default Re: doing track burnouts in second gear????? (mplex2000)
sweet, yeah i have a new clutchnet. i hope it holds up, oh well last race of the year for me so i guess it does not matter to much. also what psi should i run my bfg's at? the nittos are called for so i gotta go bfg. thanks again
Old Sep 19, 2002 | 05:50 PM
reXem's Avatar
How exactly does first not warm them up? I can hold aburnout in first gear for as long as I want and there is nice thick clouds of smoke coming from the tires...all I do is hold the revs at about 5000 and the tires just keep spinning.....
Old Sep 19, 2002 | 05:55 PM
sutrusu's Avatar
rofl
there was a new jetta at the local meet last friday w/ those graphics!
Old Sep 19, 2002 | 06:51 PM
turboex's Avatar
Default Re: doing track burnouts in second gear????? (sutrusu)
with my car when i burn out, the car starts to move forward asap. Im gonna give the first gear and second a try tomorrow, i guess i need to keep the wheels in the water
integralactic
Jun 22, 2006 05:45 AM
sa90eg
Mar 17, 2006 08:53 PM
s2kkk
Jul 19, 2005 05:11 PM
18G_prelude
Mar 26, 2004 05:31 PM
Pengo
Aug 23, 2003 09:25 PM
