With 8 lbs of boost, what are the most efficient injectors?
Old Sep 19, 2002 | 12:36 PM
integra-modder's Avatar
Default With 8 lbs of boost, what are the most efficient injectors?
running on a .47 a/r, 60mm trim, with intank walbro and AEM EMS
want to retain stock idle.
plan on sleeving next summer and pushing higher numbers.
Old Sep 19, 2002 | 01:21 PM
DIRep972's Avatar
Smarter than you
Default Re: With 8 lbs of boost, what are the most efficient injectors? (integra-modder)
smaller injectors are easier to idle with. just go as small as possible but make sure they will allow u to make power.
Old Sep 19, 2002 | 04:24 PM
Default Re: With 8 lbs of boost, what are the most efficient injectors? (DIRep972)
how much power can the 550's handle?
Old Sep 19, 2002 | 04:33 PM
ion_four's Avatar
440/450 are plenty big. You might even be able to use 370/390cc injectors. I'd just go with the 450's, though. My car idles fine and then you can run all the way up to 10+psi.
Old Sep 19, 2002 | 04:52 PM
Default Re: With 8 lbs of boost, what are the most efficient injectors? (ion_four)
i plan on upgrading to run a lot more boost next summer, so if i can id rather keep the 550's
but if i wont idle like stock, im getting something smaller
Jneri1987
May 1, 2013 07:08 PM
blocburner1
Jan 14, 2006 05:48 AM
turbo*s2k
Mar 31, 2004 03:27 PM
yaya
Mar 14, 2004 05:07 PM
pkripper94
Apr 7, 2003 07:19 PM
