*** 97 b18b turbo crx...what ECU??***
hey everyone!
right now i have a pm6 ecu which i thought was a 90-91 LS ecu but i think its a stock crx si ecu( doh!)....well anyways what ecu would you guys recommend that i run????....this ecu works well but a 1.6 liter single cam ecu running a 1.8 dohc turbo doesnt seem like it would be running at its potential! not enough fuel or somethin!
thanks for your help!
Re: *** 97 b18b turbo crx...what ECU??*** (Doodoo)
no stock ECU will run that engine properly if you are feeding it boost.
A zdyne will be less of a PITA to wire, a PR3 or PWO hondata will be fine too.
You can easily chip a PM6 so it has the same maps and redline as a PR4 - the electronics between the ECUs are identical.
Read more and ask better questions, Daniel-san. Wax-on, wax-off.
Re: *** 97 b18b turbo crx...what ECU??*** (blundar)
Re: *** 97 b18b turbo crx...what ECU??*** (boostinb18)
ttt...........should i get a LS ecu?? is anyhitng effected?? losing power??
The next best would be a 94-95 P74/5 ecu, with obd0->1 harness and obd1 distributor along with 4wire o2 sensor.
And the next bext is a PR4 ecu (90-91 integra)... that one plugs right in .
