FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (with Ceramic Coated Turbine)
Sorry to post an ad in this forum...but this would be the only forum it really belongs in...
anyways...like the topic says...i'm selling this for my friend. we both bought our turbos at the same time...and had them ceramic coated at the same time.
Specs on this GT30 are:
Dual Ball-bearing cartridge
0.82 a/r Turbine Housing (4 bolt outlet)
0.70 a/r Compressor Housing
Watercooler Center
56 Trim Compressor Wheel (T04S)
55 lbs/min Comp Flow Max.
84 Trim Turbine Wheel
External Wastegate
T3 Flange
** Ceramic Coated Turbine Housing **
i'm sure you've heard all the hype about the GT30...this is one sick puppy
Reason my friend is selling is that he decided he couldn't afford to go turbo anymore...plain and simple...the turbo is BRAND NEW...never installed.
I believe there was a GB recently and the GT30 was selling for $1550? correct me if i'm wrong...but anyways...to make this competitive...i will be letting it go for $1450 OBO...remember...i paid about $100 for the extra ceramic coating.
here are some pics of the turbo:
GT30
Standard T3/T4 vs GT30
[Modified by kidkutz, 12:11 AM 9/18/2002]
[Modified by kidkutz, 12:12 AM 9/18/2002]
Watercooler Center
External Wastegate
T3 Flange
GT30
Re: FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (Gmedalion)
i would(cause hes close to me but its a lot to spend and Im wagering on it that its WAY to big for me right now but damn i would just buy it to have it sit on my mantel
Re: FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (shortyz)
Believe it or not...this might even spool up faster than your turbo! Ball Bearings are a hell of a difference.
thats big. real big.
lol must spool at like 7k
Re: FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (Charlie)
ttt
as for the questions...i''m not sure...you'd have to ask someone that has already installed it...my car is also still in the works.
Re: FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (Me Love You Long Time!!!)
ttt
btw...spool time should be very good considering it's a dual ball-bearing turbo. really depends on your displacement, compression, and amount of boost you want to run though. i plan on running 25+ psi and hit full boost by 5200K
[Modified by kidkutz, 10:01 AM 9/19/2002]
Re: FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (kidkutz)
ttt - can vouch for this seller.....can't believe no one wants this at this price....
Re: FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (SiRkid)
that would fit perfect right on my 1.5 non vtec sohc dx ...thing should spool up by monday lol
that turbs is HUGE
that turbs is HUGE
Re: FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (89civic1.8T)
I believe there was a guy on here running a GT30 on a gsr and was hitting 10lbs at 3500rpm These are some of the best turbos
WOuld there be any way to mount this turbo on a rev hard manifold because i have a T3/To4e with a 3 intake and the turbo barelly fits with out hitting the block and I have shaved and extreme amount off the block. Could I mount the intake housing on the driver side and make it work. thanks for the help.
Da1spaz247
09-30-2007 12:04 PM
AnclyT
07-14-2007 06:18 PM
rollydc69
04-05-2004 08:26 AM
kidkutz
10-06-2002 03:33 PM
