Question for the High Altitude People
Old Sep 20, 2002 | 12:26 PM
The_Head's Avatar
Default Question for the High Altitude People
What's a good rule of thumb for max boost psi at high altitudes (4000+)?
...running 91 octane pump gas
One mechanic in my town said 10 psi. I want to know what you've heard.
I know theres a few people from Colorado and Utah lurking on the FI board.
Old Sep 20, 2002 | 03:04 PM
justinCO's Avatar
Default Re: Question for the High Altitude People (xThexHeadx)
Depends on the motor you're running? From what I've seen on turbo honda/acura's nobody really makes changes in boost levels to compensate for altitude here. I may just be dumb, but to me 8psi is 8psi no matter what altitude you're at. The turbo might have to work harder at different altitudes to generate the same pressure, I think that's the only difference. Somebody correct me if I'm wrong...
Justin
Old Sep 20, 2002 | 06:34 PM
The_Head's Avatar
Default Re: Question for the High Altitude People (justinCO)
sorry, It's a built B16A with a T3/T4E Turbo, .63 A/R exhaust, .50 A/R compressor
Old Sep 21, 2002 | 12:51 AM
ninesecrx's Avatar
Boost is not boost and altitude has a big difference on boost.
Old Sep 21, 2002 | 10:16 AM
The_Head's Avatar
Default Re: Question for the High Altitude People (ninesecrx)
I think I heard somewhere for every 1000 feet in altitude gained, it's like losing 0.5 psi in airflow, cause the air gets less dense. I dunno.
I think I'm going to stay at 0.8 BAR (~11.7 psi) just to be safe.
Old Sep 21, 2002 | 09:13 PM
justinCO's Avatar
Ok, so what's the difference? Please explain cause I'd like to know. I just don't understand how 8psi at sea level is any different than 8psi at 5280ft. Obviously the air is thinner up here and there is a noticeable difference w/ an N/A motor. But once the air is "compressed" to 8psi, you still have 8psi just like you would at sea level, no? Maybe I'm just confusing myself more, hehe. Anyone else explain this to me?
Justin
Old Sep 21, 2002 | 09:16 PM
Mr. Softee's Avatar
I agree with your logic and an curious
Old Sep 21, 2002 | 10:08 PM
98Psi ITR's Avatar
Default Re: Question for the High Altitude People (94goldjungsr)
Just because you have 8psi of "air" the oxygen percentage is not changing. Just like the NA motor you have less dense O2. I noticed just changing altitudes about a 2psi difference with stock ecu and bolt on fuel computer. 8psi at alt and 10psi at sea level. Make sure your baro correction works.
EJ8 GSR-T
Nov 12, 2007 04:21 PM
1990hondaHF
Aug 21, 2005 01:39 PM
prabtej_si
Jan 25, 2005 09:02 PM
VeilSide_Mas
Jan 15, 2003 06:26 PM
integraty
Oct 8, 2002 03:31 PM
