JRSC question
Old Sep 19, 2002 | 01:18 PM
B18Flip's Avatar
Default JRSC question
I recently looked inside my JRSC manifold and inlet and i noticed black deposits in the manifold walls. Is this normal? A friend had mentioned maybe its the bearing or a leak. PLS HELP!!
Old Sep 19, 2002 | 05:59 PM
B18Flip's Avatar
Default Re: JRSC question (B18Flip)
Anybody?
Old Sep 19, 2002 | 08:41 PM
FMXer's Avatar
yikes.
Im curious also, free bump.
Old Sep 19, 2002 | 09:28 PM
ck279's Avatar
Default Re: JRSC question (FMXer)
If you have a hose running from the crank case to your intake for positive ventilation I'm assuming you would get an oil-film build up like any other vehicle. If your not, then I'm not sure.
Old Sep 20, 2002 | 05:07 AM
Holden's Avatar
Either oil rebreathing or the blower lobes are shredding each other. You will suck a lot of oil in if you have a hose straight from the valve cover to the intake pipe.
Is your TB as oily?
Old Sep 20, 2002 | 05:33 AM
B18Flip's Avatar
Default Re: JRSC question (Holden)
Yeah, the TB is oily . So i'm guessing it it she oil rebreathing from the valvecover. Normal right?
[Modified by B18Flip, 12:27 PM 9/20/2002]
Old Sep 21, 2002 | 08:26 AM
i2un's Avatar
I was gonna post exactly what Holden said. My charger used to suck oil out of my valve cover via the hose from the valve cover connected to my air intake.
The easy fix would be to cap the air intake off and install a breather filter on the valve cover...or do what I did and get a catch can. Either will work well.
poland accord
Aug 7, 2008 07:45 PM
Rick
Sep 27, 2003 05:33 AM
DeDonDeRosa
Apr 18, 2003 04:41 AM
The-LS
Apr 18, 2003 04:32 AM
-Whitey-
Sep 28, 2002 09:36 PM
