AVCR Boost Setting Q's
Old Sep 19, 2002 | 10:58 PM
SUMORex's Avatar
Default AVCR Boost Setting Q's
I have had my avcr running for a while but curious about some things...
On my boost setting i have the boost set at .80 bar
As for the Duty Cyle i have it 60%
Now here's the wierd thing.... On the Boost Guage it reads only 9-10 psi on WOT
Do i have the settings wrong?
What does the Duty Cycle control?
And what bar reading is it if i want to run 11 psi?
Im currently running the hondata and has been tuned on the dyno. I have a JDM Built B16 on a 2000 Civic Greddy Kit and a Spearco Intercooler. I know the cardinal rule is that you loose some boost becuase of the FMIC, but does the guage read what is being produced or is it pre-boost readings...
Help me out guys....
Old Sep 19, 2002 | 11:15 PM
dustin's Avatar
Default Re: AVCR Boost Setting Q's (SUMORex)
Where is the AVC-R map sensor tapped?
Old Sep 19, 2002 | 11:27 PM
SUMORex's Avatar
Default Re: AVCR Boost Setting Q's (dustin)
The Boost Control Valve is connected to the Internal WG and a vac source on the Mani.
The Map i am assuming is connected to one of the vac lines coming off of the TB.
What is .8 bar anyways?
Old Sep 19, 2002 | 11:32 PM
Dee's Avatar
Dee
.8bar = 11.6psi
Old Sep 20, 2002 | 12:00 AM
SUMORex's Avatar
Default Re: AVCR Boost Setting Q's (Dee)
If .8 is 11.6 psi, and i see 10 then i am loosing 1.5 psi through the FMIC??
Is that correct?
And if so then can i raise the boost setting to .9 Bar?
redlinetuning
May 7, 2009 08:41 AM
civic_66
Feb 14, 2007 07:22 AM
BauleyCivic
Jul 11, 2006 07:36 AM
slowcivic
Apr 25, 2003 09:23 AM
redline201
Dec 3, 2002 04:35 PM
