went to track tonight
Old Sep 18, 2002 | 08:02 PM
vtecsiqt's Avatar
Default went to track tonight
I have a 94 Integra LS w/ Drag gen 3 kit @10p.s.i., stock wheel and all season tires....1st run was: 15.574@99.38, w/ 2.505 60ft......2nd run was: 14.990@103.39, w/ 2.703 60ft.....1st run I had massive wheel hop when I took of, then in 3rd gear my clutch either slipped like crazy or I hit an oil slick...don't know.....2nd run I had a bad take off, bogged pretty bad at the line...........what do you think I should be getting for e.t. with some improvements????..........only my second time dragging, I SUCK!
Old Sep 18, 2002 | 08:06 PM
Mase's Avatar
Default Re: went to track tonight (vtecsiqt)
my best time at the track my first time w/ the drag 3 and fmu was 14.1 on shitty steelies @ 8 psi
Old Sep 18, 2002 | 08:14 PM
avividmemory's Avatar
Default Re: went to track tonight (CDooMe2)
what are you guys lauching at??
Old Sep 18, 2002 | 08:16 PM
Mase's Avatar
Default Re: went to track tonight (SpoolinLS)
it all depends on the track conditions, but mostly on the tires....tonight i was launching at about 4000 rpms. a couple months ago i was only launching at 2700rpm with the same piece of **** tires.
Old Sep 18, 2002 | 08:23 PM
SoulSurfer's Avatar
Is that all the Drag III is good for, 14's? They're decent times but I'd expect much better.
Edit*...What's your 60' time?
[Modified by LSDelSol, 2:25 PM 9/19/2002]
Old Sep 18, 2002 | 08:25 PM
Mase's Avatar
Default Re: went to track tonight (LSDelSol)
hey now, i ran a 13.7 tonight w/ my drag kit, and if i had traction, id get much better times....
Old Sep 18, 2002 | 08:32 PM
Teg4e's Avatar
103 mph is good for high 13's. Get some stickier tires (azenis or DR's) and practice that launch. That's what's killing you. The MPH is the biggest indicator of the power you're making, so you're fine in that regard.
edit: maybe mid 13's
[Modified by Teg4e, 1:02 AM 9/19/2002]
Old Sep 18, 2002 | 08:39 PM
SoulSurfer's Avatar
Thats what I wanted to hear...good job.
Old Sep 18, 2002 | 08:50 PM
Mase's Avatar
hey, so much for using your High flow cat. lol i sold my turbo kit, however, im gonna keep it incase i buy another turbo
Old Sep 18, 2002 | 08:54 PM
SoulSurfer's Avatar
Ha ha...that sucks man...so you're the 2nd owner to never use it.
Old Sep 18, 2002 | 08:56 PM
Mase's Avatar
lol oh well, the box is nice to look at haha.
Old Sep 19, 2002 | 07:36 AM
SiR Kid's Avatar
New User
WOW, those are some bad launching timeslips!
Don't worry, there's nowhere to go but down (in times that is)
Try launching the car off idle, and just ease it down the track. Drive it like you're on the street, trying to get through traffic REALLY quickly, cause an LS turbo will make enough torque to blow off the tires in 1st, 2nd and probably well into third.
Hope this helps.
CRXherbie91
Jun 10, 2008 03:42 PM
boost fed ls
Apr 12, 2004 04:41 PM
boost fed ls
Apr 4, 2004 10:42 AM
R THIS
Aug 10, 2003 04:43 AM
95c1v1cs1
Jun 9, 2003 04:11 PM
