is 990cc injectors to big?
my friend is selling me a set of 990cc injectors(low impedence) for $250 new. he says he needs the money, are these to be for a b18b daily driver turbo?
oh i forgot to ask, whats the deal with the impedence? i don't have a clue on it.
here's a link to some popular injectors and the flow rate. http://www.allmotorhonda.com/techpages/injector.htm
saturated injectors = high impedence; peak-and-hold injectors = low impedence
to run low-impedence injectors on a car that originally came with high-impedence injectors, it is necesary to run a resistor box of some sort, or you will fry your ecu. lots of old hondas came with resisotrs boxes and they can be had for really cheap...just take a look around here and you will find one.
and yes, what are your HP goals? 900cc is probably too big for you...unless you are shootign for 600-700 hp.
get your head ported and polished w/ intake mani and you should have 300whp with 11-12psi with good tunning.
There are 550cc-720cc injectors for $200-$300 all over thepartstrader.com, just do a search.
oh one more question, would it be better to use a msd 6BTM or a msd 7AL-2
or you could save your money and keep the stock ignition. i have heard of many ppl upwards of 400hp w/ stock ignition...u need the right plugs gapped correctky of course...
b16bri
Sep 5, 2010 02:53 PM
