cracks in the exhaust manifold
Old Nov 30, 2002 | 03:55 PM
ludelvr's Avatar
Default cracks in the exhaust manifold
What are some of the symptoms that you have a crack(s) on you exhaust manifold?
Old Nov 30, 2002 | 04:05 PM
ninesecrx's Avatar
Default Re: cracks in the exhaust manifold (ludelvr)
exhuast gas comes out and bites you on the nose.
Old Nov 30, 2002 | 04:57 PM
ludelvr's Avatar
Default Re: cracks in the exhaust manifold (ninesecrx)
what are some of the ill effects of having cracks on your exhaust manifold? How can it be detrimental to a turbo car?
Old Nov 30, 2002 | 05:31 PM
falcongsr's Avatar
What is this crap?
if the cracks are bad enough to allow lots of gasses out then the turbo wont spool as well or not at all. if you just have little cracks in your manifold, then its ok for now but plan on replacing it down the road.
Old Dec 2, 2002 | 09:45 AM
ludelvr's Avatar
Default Re: cracks in the exhaust manifold (falc0n)
exactly how little is a little crack? Cuz I look at these and it is about a few millimeters in width but the lenth is a good 2 inches or so. It was where one of the welds was made. Also, there is a 90 degree crack the is somewhat bent upwards. This is only on the top too, I'm not sure what's on the bottom.
Old Dec 2, 2002 | 11:18 AM
Full-Race Javier's Avatar
the leaking sound is annoying
Old Dec 2, 2002 | 12:23 PM
flip1199's Avatar
Default Re:
what manifold do you have?
Old Dec 2, 2002 | 12:32 PM
b18b98's Avatar
Default Re: Re: (flip1199)
Doesn't white carbon deposits on a part of the manifold means that part has a crack in it?
Old Dec 2, 2002 | 01:02 PM
ludelvr's Avatar
I have a custom made manifold. I was originally using a ct26 but then swapped out for a t3 and then I had to move the flange over. when I did this, the spot where we welded up started to crack and now it's a pretty large crack that goes right through the wall fo the tubing.
Old Dec 2, 2002 | 02:13 PM
falcongsr's Avatar
What is this crap?
Default Re: Re: (b18b98)
black deposits. not white.
if there is exhaust gas coming out of any crack, then i'd look at getting a new manifold immediately!
2mm wide sounds pretty big to me - i would be worried - but thats my opinion and i am no expert.
Old Dec 2, 2002 | 06:22 PM
b18b98's Avatar
Default Re: Re: (falc0n)
whew...i thought i had to get this manifold welded or buy an inline pro.
RDX2010
Oct 6, 2017 05:59 PM
t70accord
Welding / Fabrication
Jan 9, 2014 05:50 PM
PHiZ
Jan 31, 2004 06:04 PM
