Low Impedence or High Impedence ?
I just finished installing my motor (gsr) and im about to crank it soon. I bought some used MSD 82lbs. injectors a while back and i was wondering if anyone knows if they are low impedence (peak & hold) or high impedence (saturated). I was told that they were saturated (high impedence) but i just want some second opinion before i start it, i dont want to fry or short anything out. To those that have experienced MSD injectors, please shed me some light on this. Thanx and much appreciated.
EDIT: I will be using Speedpro (F.A.S.T.) ECU.
[Modified by TurboDANDEE, 10:39 AM 12/1/2002]
Re: Low Impedence or High Impedence ? (TurboDANDEE)
the msd 82lbs. injectors are low impedence (peak & hold) so your gonna have to get a resister box and clips if you dont wanna burn your ecu.
Re: Low Impedence or High Impedence ? (BEe18SeAONe)
Depends on what ecu you are running the speed pro wont need any changes but if you running hondata or aem or something that runs factorry injectors then you would need the resitor pack..
This is a reply that i got back earlier right after i purchased my injectors. Any truth to this, because this says that i dont need a resistor box if im running Speedpro. Someone help me out because im about to start my car and i dont want anything going wrong, thanx.
try and start it if you smell something burning then i guess you needed the resister box.
ya i was just jokeing anyways, personally i would contact whoever makes Speedpro (F.A.S.T.) ECU. and ask them. good luck
Re: Low Impedence or High Impedence ? (boostaholic)
Speedpro has a built in injector driver for low impendence injectors. So with those injectors, you're good to go.
Hey, if you dont mind, i might hit u up again if i need anymore wiring help. thanx again man.
like chris said above.. you are good 2 go with the ones you have. You can call me if you have any questions. I think David gave you my #.
Re: Low Impedence or High Impedence ? (GSRev)
Ya thanx Alex I will definetly give you a call. I might need your help with some base map and setting it up to get it started. I just dropped in my motor lastnite, i just need to finish up some wiring and little nick nacks. thanx dude.
bigblue7t6
Engine Management and Tuning
10-05-2012 08:31 PM
glagola1
07-21-2002 02:29 PM
