Drag III LS, having startup problems.
Old Nov 27, 2002 | 12:00 PM
TedR719's Avatar
Default Drag III LS, having startup problems.
Recently installed a DRAG III kit on an 97 LS and now it's having problems starting up. It takes about an hour before it will fire up and run. After it starts up it runs perfect!
Any ideas on what this could be?
They have replaced the spark plugs, check the cap/rotor...
Old Nov 27, 2002 | 11:25 PM
TedR719's Avatar
Default Re: Drag III LS, having startup problems. (futuresi)
ttt
Old Nov 27, 2002 | 11:35 PM
Adi Radoncic's Avatar
On Fire!
Was the car in good running condition before the turbo kit was installed on it??
Also you might just go through and check if all of the vacume lines were plugged in and if you have any fuel leaks or anything like that, just basicly go through and check over your install agian??
Adi
P.S. Is your check engine light on??
Old Nov 27, 2002 | 11:42 PM
TedR719's Avatar
Default Re: Drag III LS, having startup problems. (newgsr)
Yup the car was in great shape before the install.
There is no CEL. He said after it gets started the car runs perfect, so kinda stumped....
any other ideas?
Old Nov 27, 2002 | 11:50 PM
dwilson's Avatar
Maybe it is a ground wire loose. My brothers ground to his starter was loose sometimes it would start and some times it wouldnt just a thought.
Old Nov 28, 2002 | 10:31 AM
TedR719's Avatar
Default Re: Drag III LS, having startup problems. (dwilson)
Cool I will chck that out
Old Nov 28, 2002 | 10:44 AM
HybridKOOP's Avatar
Inline fuel pump installed backwards?
Old Nov 29, 2002 | 06:54 AM
TedR719's Avatar
Default Re: Drag III LS, having startup problems. (HybridKOOP)
We took the one that came with the kit off cause it was pumping out way too much fuel, almost 80psi. So he is using his stock setup.
Old Nov 29, 2002 | 07:32 AM
MIKES's Avatar
Did you mess around with the cam timming at all? A fitting in the back of the block, oil pan, and exhaust manifold won't cause that problem. Its probably a plugged fuel filter, or bad injectors. I would start off by checking cam timing and pulling the distributer cap and putting the motor to top dead center, and checking to make sure that the rotor is pointing at the #1 spark plug wire. Did you also use check valves or missing links? still have the stock map sensor? You should put back in that pump that came with the kit and get a adjustable fuel regulator to turn down the psi. Also when you are trying to start the car. Do you smell the engine flooding with fuel? if not check your pump or fuses. Do you have spark? pull off a spark plug wire and stuff a old plug in it and try to start it up and look to see if you got spark. Lastly is the starter engaging when you crank it over, or is everything dead? If everything is dead, try running a new ground from your tranny to the body of the car.
[Modified by MIKES, 4:36 PM 11/29/2002]
Old Nov 29, 2002 | 08:25 AM
Speed PHreak's Avatar
Default Re: Drag III LS, having startup problems. (MIKES)
Word, for one. Go back and double check your grounds. Make sure you check Tranny --> Body, Valve Cover --> Body, and the grounding point on your thermostat(that on is for your ECU. It wouldn't hurt to clean ALL those groundings points with some steel wool.
Also the fuel puslation dampener on your fuel rail can cause hard starting if it goes bad. It's the round mushroom looking deal opposite the FPR on the fuel rail. That little device makes sure that the rail stays pressurized and doesn't back flow when the pump is off.
Old Dec 8, 2002 | 01:34 PM
TedR719's Avatar
Default Re: Drag III LS, having startup problems. (Speed PHreak)
Well it was the APEXi SAFC giving it problems, took it off and now it's just fine.
bassplayer
Dec 29, 2009 01:49 PM
Cowboy
May 29, 2003 10:35 AM
Arturbo
Oct 8, 2001 01:06 PM
ImprtTunr
Jul 16, 2001 06:08 PM
