noob nitrous q?
Old Nov 27, 2002 | 05:27 PM
hondaeg5's Avatar
Default noob nitrous q?
im gonna install a n.o.s 50 shot dry. i searched archives and just wanted other opinions. should i upgrade the fuel pump?retard the timing? i know i need colder plugs. what else would you suggest? go ahead flame away! what do you think this might do for my 1/4 mile times? TIA
Old Nov 27, 2002 | 05:30 PM
Jared's Avatar
Default Re: noob nitrous q? (hondaeg5)
nice sig
Old Nov 27, 2002 | 06:42 PM
EVOCELICA's Avatar
New User
50 shot just leave everything stock, you'll be fine. You can get a step colder plug and always run premium grade gas. Just make sure you install it correctly and use the fuel pressure hobb switch with the kit.
Old Nov 27, 2002 | 07:52 PM
laughinxxx's Avatar
New User
Default Re: noob nitrous q? (EVOCELICA)
Get a purge kit so that you keep the nitrous pressure off of your noid seals when you aren't using it. And get colder plugs.
Old Nov 27, 2002 | 08:57 PM
EVOCELICA's Avatar
New User
Default Re: noob nitrous q? (laughinxxx)
purge kit will not aleaviate pressure on the primary nitrous solinoid, the solinoids are designed to withstand the pressure from the bottle. IMO the purge valve is good for checking to see if there is nitrous still left in the bottle.
Old Nov 27, 2002 | 10:26 PM
laughinxxx's Avatar
New User
1. purge kit will not aleaviate pressure on the primary nitrous solinoid
2. the solinoids are designed to withstand the pressure from the bottle.
1. Before you spray it is common practice to purge out the old nitrous until you see a nice white cloud. After you make your run, close the bottle, and purge the nitrous out of the line. This gets rid of the pressure on the seals.
2. I'm not talking about the solenoid. The solenoid is made of metal it won't deform because of the 100 psi coming from the nitrous. I am talking about the little, piece-of-**** rubber seals that NOS uses in their super powershot solenoids. When exposed to high temperatures the rubber will become supple, and a nice nipple will form on the seal effectively blocking about half of your nitrous. I'd show you a picture of the 5 of mine that are shot to ****, but I had to send them to NOS so that they would send me stronger seals for free. In their larger noids NOS uses teflon seals and I believe the ones that I was sent are made of cadnium, but I could be wrong.
If you want to know if you have nitrous left, weigh the bottle.
Old Nov 28, 2002 | 12:09 AM
hondaeg5's Avatar
thanks for the info guys!
JDMDC4life
Oct 12, 2006 02:18 PM
KURUPTinc
Feb 26, 2006 05:46 PM
mk2
Jan 5, 2005 07:51 PM
bulryder7
May 15, 2002 02:24 PM
