Proper break in of new motor
Old Dec 1, 2002 | 11:51 AM
B18C-RnVA's Avatar
New User
Default Proper break in of new motor
well my car is comming out the shop tomorrow and i was wondering about proper break in of the motor..ive heard different ways but trying to get one good way to properly break it in with turbo hooked up...of course im going to baby the car but i have questions like...
How many miles before i can go into boost??
How long before i can change to syntheic oil?? if that even really matters.
i was told highway miles are not good for proper break in, true or false??
should i change the oil every 200 miles until i reach 1000 miles?
Also what weight should i run....10/30, 5/30, or what??
Old Dec 1, 2002 | 12:09 PM
TurboGabe's Avatar
Default Re: Proper break in of new motor (B18C-RnVA)
https://honda-tech.com/zerothread?id=214707
https://honda-tech.com/zerothread?id=234489
[Modified by TurboGabe, 9:10 PM 12/1/2002]
Old Dec 1, 2002 | 01:40 PM
B18C-RnVA's Avatar
New User
Default Re: Proper break in of new motor (TurboGabe)
thanks turbogabe
Old Dec 1, 2002 | 01:50 PM
B18C-RnVA's Avatar
New User
i just want to make sure that im not smoking...spent to much on the motor to be riding around smoking..another question
should a freshly rebuilt motor smoke, even for a little bit??
Old Dec 1, 2002 | 02:23 PM
yellowsub's Avatar
Until the rings seat.
Old Dec 1, 2002 | 02:26 PM
Lei Siew Long's Avatar
this is the method i used during the break in procedure of my newly built engine:
use mobil 10w-30 conventional oil.
start the motor, hold it at a steady idle at 2000 rpm for about 20 minutes. of course, check for leaks and anything out of the ordinary during this crucial period. don't forget to do a proper bleeding of the coolant sysetm as well. once complete, set the timing and double check everything.
0-200 miles: use a 3000 rpm rev limit. try not to lug the motor and avoid steady state cruising. vary the loads with a few first gear "zings" to 4500 rpm. of course, make sure, the car is properly tuned and in proper working order for higher rpms. but, don't get greedy and don't think you have to zing the motor either.
200-400 miles: rev limit is 3500 rpm. the zing limit is 5500 rpm in first and include partial second gear. the rest remains the same.
400-600 miles: rev limit is 4000 rpm. zing limit is 5500 rpm. include partial third gear. rest remains the same.
600-800 miles: rev limit 4500 rpm. zing to 6500 rpm and include partial fourth gear pull.
800-1000 miles: rev limit is 5000 rpm. zing to 7500+ and include partial and infrequent fifth gear pulls.
OIL CHANGES: 100 miles, 300 miles, 500 miles, 800 miles and 1000 miles.
Once complete, change the oil and filter, check the plugs, perform a valve adjustment, and compression test.
Personally, i performed my break in 'til 1500 miles and the oil changes might be overkill, but, better safe than sorry.
SupraRXZ
10
Jun 13, 2007 02:32 PM
95BlkGSR
Jun 29, 2005 07:38 AM
Nextelbuddy
Feb 20, 2004 05:51 PM
R-gonaut
33
Jul 31, 2002 10:40 AM
Hard2Find
Jul 2, 2002 05:11 PM
