Okay to remove fuel pump?
Old Nov 27, 2002 | 09:48 AM
Andrew 825SM's Avatar
Default Okay to remove fuel pump?
Since I have an inline fuel pump, is it okay to remove my walbro intank pump and just adapt a hose to it. I heard the intank pump may act as a restrictor as it does not flow as much as the inline.
Old Nov 27, 2002 | 11:30 AM
turbosol's Avatar
Default Re: Okay to remove fuel pump? (Airtracks)
That would'nt be a very good idea. I'd just leave it, but if you want to do something you could put your stock pump back in. I personally don't see any reason not to run the intank along with the inline. Your choice. The inline is not designed to work by it's self.
Old Nov 27, 2002 | 12:18 PM
highbrid's Avatar
Default Re: Okay to remove fuel pump? (turbosol)
if you talk to some they will tell you to remove the stock pump and bypass it if you have an inline.
http://www.theoldone.com
Depending on where you have your inline mounted you could remove your intake. Just remember that an inline pushes much better than it pulls.
wernhersey
Oct 6, 2008 03:44 PM
1 2 NV
Sep 4, 2002 12:44 PM
recall
May 5, 2002 04:11 PM
integra7
Nov 28, 2001 03:04 PM
LudeSi-93
Jun 25, 2001 04:19 PM
