Car is hessitating...Why?
Old Nov 27, 2002 | 10:50 PM
TheIntegraGuy's Avatar
Default Car is hessitating...Why?
Well...I don't know if you guys read my previous threads but my car didnt start for a while.
It was so stupid I don't even want to say why. I guess all the problems are so fustrating until you find out that it was something so small and it turns out to be silly instead of fustrating.
Anyways, before my car "didn't start" it was hessitating. If I were to step on the gas, there would be a delay for a bit and then it would be normal. I guess you can say it kinda lags at low RPM's. I'm not too sure what can be wrong. The spark plugs are fine and all coils are perfect. Anyone have any suggestions?
-ThankS.
Old Nov 27, 2002 | 11:29 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Car is hessitating...Why? (Esone3)
I think your talking about the delay that happens between going from low throttle to full throttle caused by the fmu. What happens is when you are driving at a constant speed or just sitting there at the line your car is sitting in negative vacum in which the fmu is not building any fuel pressure, so lets say your sitting in 2nd gear at 30mph at a constant throttle and you floor your car it bogs down for a second which is caused by running out of fuel pressure because your still in negative vacum and the fmu is not working but once you get posstive vacum or boost pressure your fmu starts working and everything is great and the power is all there..
Thats also why they are called boost dependant Fmu's.
I hope that I was of some help.
Adi
Old Nov 28, 2002 | 01:20 AM
Flamenco-T's Avatar
Default Re: Car is hessitating...Why? (newgsr)
you might wanna check to see if the fmu disk is sticking or not...
Costco
Nov 17, 2011 06:29 PM
mitchell_2kSiR
Nov 2, 2008 09:00 PM
all_motorsi
May 11, 2007 11:46 PM
Kaji
Aug 25, 2005 09:48 PM
Braco11
Jun 16, 2004 10:28 AM
