Fact or fiction?
Old Nov 30, 2002 | 12:00 AM
Goldfingiz's Avatar
Default Fact or fiction?
Do certain piston rings require different types of honing? Someone told me there are 2 types of honding for different piston rings. One type of honing being with a ball, the other being with knives. Is this just bogus? What would stock LS pistons/rings require? If that makes no sense, I apologize. It's 4AM and I haven't slept in days ;P
Thanks,
Goldfingiz
Old Nov 30, 2002 | 05:21 AM
frknfast1's Avatar
Default Re: Fact or fiction? (Goldfingiz)
A cross hatch hone should work just fine for stock LS rings..... I used it when I built my H22A..... worked just fine.....
Old Nov 30, 2002 | 08:40 AM
QuickHonda's Avatar
Default Re: Fact or fiction? (frknfast1)
All the different types of hones will give the same results. I suspect the truth behind this rumor is that some types of rings like the crosshatch pattern to be at a different angle than stock. Some ring manufacturers like a 60 degree pattern while i've seen ones as small as 30 and as big as 90 before.
Old Nov 30, 2002 | 11:06 AM
Jared's Avatar
Default Re: Fact or fiction? (QuickHonda)
just ask your ring manufacturer before you go honing. stock seem to like a good 60 deg crosshatch. i use a ball hone on everything, works great.
Old Nov 30, 2002 | 05:33 PM
CRVRX's Avatar
Default Re: Fact or fiction? (Jared)
Most rings need a 60 deg cross hatch , the ring manufacturer will tell you what to use. If you are using Honda rings , they specify a 60 deg with a 320 gritt stone , check your honda manual it will say .
Old Nov 30, 2002 | 07:28 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Fact or fiction? (CRVRX)
what about the ones that come with the arias pistons.
eg:R
Jun 19, 2009 10:12 PM
95blackEG
May 23, 2007 02:50 PM
Ls4thGen
Apr 27, 2005 09:41 AM
JDMCRX
Jul 4, 2003 12:58 PM
rioninja
Jul 31, 2001 05:37 PM
