My dyno results!!
Old Nov 29, 2002 | 02:35 PM
99EBPguy's Avatar
Default My dyno results!!
Well, did a little tuning on Wed. at Clemons Performance in Indiana. My setup is as as follows.
-Drag 3 Turbo kit
-Tial Wastgate
-Blitz BOV
-Act clutch
-Hondata 4b
-Rc 440's
-Paxton Fpr rising rate
-Profec B
and some other stuff, but u get the idea
[Modified by 99EBPguy, 11:48 PM 11/29/2002]
Old Nov 29, 2002 | 02:39 PM
easy jesus_151's Avatar
Default Re: My dyno results!! (99EBPguy)
I can't see anything.
Old Nov 29, 2002 | 02:43 PM
Default Re: My dyno results!! (erknjerk151)
fixed...
Old Nov 29, 2002 | 02:44 PM
99EBPguy's Avatar
so waht do u all think about my airfuel curve?? U think its stable enough??
Also did a compression test, it was 205, 205, 165, 205, number 3's minimum is 135 so....i know the compression isnt as good as it should be.
[Modified by 99EBPguy, 11:47 PM 11/29/2002]
Smashback's Avatar
guess again
Old Nov 29, 2002 | 02:50 PM
Jared's Avatar
Default Re: My dyno results!! (Hatchblack)
cut and paste guys, imagestation doesnt allow outside linking to their images.
91CivicSi's Avatar
If it were mine I would tune it a bit richer. 13:1 is a little too much air for my tastes. I hope you didn't drive it hard before you got it tuned..that red A/F line is scary. Sounds like #3 crapped out on you.
Nice numbers though..how much boost?
Old Nov 29, 2002 | 02:54 PM
99EBPguy's Avatar
Default Re: My dyno results!! (91CivicSi)
9-10 psi. The wideband we used was a sniffer. No, that was like 1 run that it got that lean, i turned my boost up a bit, and it was too much, didnt supply enough fuel.
Old Nov 29, 2002 | 03:00 PM
gritsak's Avatar
ide try and get the a/f closer to 12:1 if you are running pump gas on the street...you might get away running a little leaner for awhile but its defintely not worth taking the risk IMO.
Old Nov 29, 2002 | 03:29 PM
degradated's Avatar
New User
Looks a bit lean to me..
Old Nov 29, 2002 | 04:27 PM
avividmemory's Avatar
Default Re: My dyno results!! (degradated)
and a bit unstable on the compression...but overall good numbers for that amount of boost
Old Nov 29, 2002 | 05:08 PM
b18turbocivic's Avatar
Default Re: My dyno results!! (SpoolinLS)
Do you guys think he is running lean because of the injector size or because of lack of pressure? I ask because my setup is kind of the same and when i went to the dyno it was running hella rich up to about 5800 rpm and after that it would lean out quite a bit. The guy at the dyno said that was most likely fuel pressure related since my intank pump is to small (190 lph) compared to what most of you guys use (255 lph).
So my question is do you have a stock pump or are you running aftermarket?
And yeah looks like #3 crapped out.
[Modified by b18turbocivic, 2:10 AM 11/30/2002]
Old Nov 29, 2002 | 05:29 PM
willyboyK20's Avatar
Default Re: My dyno results!! (b18turbocivic)
why are using a rising rate fpr with hondata? don't u need a 1:1 when using the hondata?
Old Nov 29, 2002 | 09:21 PM
99EBPguy's Avatar
Default Re: My dyno results!! (willyboyD16)
Im using the stock fuel pump. And the paxton is 1:1
Old Nov 29, 2002 | 10:30 PM
gritsak's Avatar
you need to get a bigger fuel pump in, theres no way the stock one can keep up with 200+whp.
Old Nov 29, 2002 | 10:48 PM
RyanAutry's Avatar
Default Re: My dyno results!! (gritsak)
Yes it will...
Both my friend and I have stock fuel pumps. 220whp for both of us.
440cc injectors, 50psi, 80% Duty Cycle.
Old Nov 30, 2002 | 10:17 AM
gritsak's Avatar
Default Re: My dyno results!! (RyanAutry)
Yes it will...
then i stand corrected...are you also using a 1:1 FPR? i wouldnt think the stock pump can handle the power hes making without an fmu or something that raises the pressure alot as boost comes on, but who knows.....eitherway ide get a walrbo 255, they are only $115 and flow alot more
[Modified by gritsak, 7:24 PM 11/30/2002]
Darin D.
Nov 21, 2004 11:19 PM
bigedx
Apr 17, 2004 05:22 PM
BoostedH23a1
Dec 9, 2002 09:55 AM
Tegman88
Nov 25, 2002 10:46 PM
t3 typeR
Nov 20, 2002 07:38 AM
