Does this sound strange?
Old Nov 26, 2002 | 05:20 PM
TheIntegraGuy's Avatar
Default Does this sound strange?
My car hasn't been started because there is no fuel going through the regulator. I'm not sure why but if it doesn't go through the regulator, it won't go through the rail and out the injectors, thus causing my car not to start.
It cranks fine and all cylinders are firing. All fuses are checked and okay.
I changed the fuel pump, the fuel filter, regulator, and the fuel pump relay just to make sure. Still no start and I'm getting really confused about what might be wrong. I can crank it and it'll sound like it's cranking fine just no fuel, which is the problem.
Pressure in the fuel lines should be fine considering I changed the pump, and the filter so everything is like brand new. It just seems theres a clog somewhere....But I just changed the regulator and nothing makes any sense. can anyone please help me out?
-ThankS
Old Nov 26, 2002 | 05:32 PM
SlowB16's Avatar
Default Re: Does this sound strange? (Esone3)
Triple check to make sure everything is connected.... does it sound normal? Is there a sound of pressure somewhere? You could try having someone else start it and try to listen for strange noises.....
SlowB16's Avatar
Default Re: Does this sound strange? (SlowB16)
Maybe your filter has something in it?
Old Nov 26, 2002 | 05:56 PM
Filter has just been replaced last week..all connections are okay and it cranks fine but check this out..I think it MIGHT be the problem..
I took off the regulator, poured fuel inside the rail, and put back the regulator..cranked it, and fuel came out of the injectors..!.Not that much, but you can tell that theres not enough pressure pushing it through.
Then I took OFF the regulator with the fuel lines attatched to it, cranked it..and NO fuel came out of the regulator..could that be the problem?
Old Nov 26, 2002 | 05:59 PM
01geeser's Avatar
New User
hows ur pump? does it prime ?
Old Nov 26, 2002 | 06:08 PM
Default Re: Does this sound strange? (01geeser)
yeah..It's brand spakin new. Haha...Fuel goes to the front of the car, just not in the motor..I think its the regulator.
Old Nov 26, 2002 | 06:18 PM
dbman96's Avatar
New User
If you took OFF the regulator and no fuel comes out when the car is turned on and/or cranking, your fuel pump is NOT working.
Old Nov 26, 2002 | 07:06 PM
Default Re: Does this sound strange? (dbman96)
Fuel IS coming. Fuel pump works perfectly. If I take off the fuel line to the regulator, and if I crank it, fuel comes out, indicating it IS working. But, when I have the fuel line attatched to the regulator, and I crank it, fuel still gets there, but it doesn't go through.
Old Nov 26, 2002 | 07:13 PM
SIK IN DA HED's Avatar
New User
then it might be your fpr.
Dc295kid
Nov 26, 2008 07:26 PM
Stray
13
Jun 17, 2007 06:55 PM
EGNA
Jul 12, 2006 03:31 PM
StraightCivic
Apr 24, 2006 03:58 AM
Espec_rep
Nov 25, 2005 01:01 PM
