crx downpipe
Old Nov 28, 2002 | 09:05 AM
BoostedED9's Avatar
Default crx downpipe
*i did a search and nothing*
I was wondering if anyone is runing a 3" dp on a crx, i need to figure out how it runs so i can make mine, if anyone can tell me what radius the 3" bends should be i would really appreciate it and pics would be a big +
thanks
Old Nov 28, 2002 | 09:13 AM
racerxadam's Avatar
Default Re: crx downpipe (BoostedED9)
Are you running an aftermarket cross-member? It will be very difficult to fit a 3" dp and still keep the factory cross member
Old Nov 28, 2002 | 09:32 AM
AR Fab's Avatar
Default Re: crx downpipe (racerxadam)
Exhaust Donuts work well for very very tight radius'....Chassis Shop
Howard
Old Nov 28, 2002 | 11:31 AM
BoostedED9's Avatar
Default Re: crx downpipe (AR Fab)
stock xmember
Old Nov 28, 2002 | 01:07 PM
true's Avatar
I have a 3" downpipe on my crx. I was using stock front crossmember...tight, but it will work fine. I ended up using the place racing crossmember, but that was for the turbo drain. The problem you will have is (assuming you are using civic short radiator) making a pipe with a good bend while clearing the radiator. I decided to make a nice non-cheated pipe smooth pipe and just get a custom radiator. Some pics at thread: https://honda-tech.com/zerothread?id=266936 I have more somewhere if your interested.
[Modified by true, 10:08 PM 11/28/2002]
Old Nov 28, 2002 | 07:27 PM
BoostedED9's Avatar
Default Re: crx downpipe (true)
damn that looks nice man, but i have my turbo on with the compressor facing the passanger side.. i tried mounting it the other way but the turbine housing would hit the radiator, if it wasnt for htat it would of been sooooo easy. this is my current dp, i wanna do a full exhaust b/c its too much of a cop magnet...
[Modified by BoostedED9, 11:27 PM 11/28/2002]
Old Nov 28, 2002 | 07:42 PM
SiR Kid's Avatar
New User
I'll have a 3" DP on my car soon.. within the next month. I'll post pics
Old Nov 28, 2002 | 08:27 PM
yellowsub's Avatar
Default Re: crx downpipe (SiR Kid)
The shocker has a 3" that was made for his car. Ill have him post some pics of it.
Old Nov 28, 2002 | 09:23 PM
shortyz's Avatar
Default Re: crx downpipe (yellowsub)
i got a downpipe off a audi and it looks pretty good. got O2 sensor in the cast casing and everything. can i get the muffler shop to re bend it for me?
also i picked up a audi wastegate and it has the normal vacuum line and a large hole in the side with threads.. what is that large hole for? and is this audi WG even worth anything?
Old Nov 28, 2002 | 10:20 PM
Smoothy's Avatar
I used 3" radius bends for mine. Probably could have saved AC, but it would made tightening the bolts very difficult. I ran a full CRX Fluidyne, and stock cross member.
1FSTNDN
Jun 23, 2006 07:17 AM
crxrocks
Mar 19, 2006 08:33 AM
miketurbohonda
May 5, 2004 01:51 AM
Vera
26
May 3, 2004 06:37 AM
SUMORex
Mar 12, 2002 02:59 PM
