K26 K24?
Old Nov 26, 2002 | 03:09 PM
shortyz's Avatar
Default K26 K24?
how are these turbos i might go pick one up off an audi.
i got a little d16 would it work ok?
Old Nov 26, 2002 | 04:37 PM
shortyz's Avatar
Default Re: K26 K24? (shortyz)
im hearing the wind whisp past my ears.
can someone give me a link where i can figure out what this diagram means?i dont get how i interpret the graph.
[Modified by shortyz, 2:20 AM 11/27/2002]
Old Nov 26, 2002 | 06:06 PM
shortyz's Avatar
Airflow = (2/1000)*0.9*(R/E)*S*(303/360)*146.5
ok guys. 1 problem that graph is in m^3s . which converts to CFM 208 CFM @ .10 m^3s
now how do i get psi off that X axis?
Old Nov 26, 2002 | 06:44 PM
Sonny's Avatar
You don't get PSI off of the X axis. On the X axis is compressor flow, usually measured in LB/MIN. On the Y axis is pressure ratio.
Pressure Ratio = (Boost Pressure + 14.7) / 14.7
For example, boost = 7.3 psi. PR = 1.5
Sonny
mrx
Jul 30, 2007 12:39 PM
Jared
Feb 27, 2006 07:25 PM
Goldfingiz
Jul 22, 2003 12:06 PM
fire7882
Sep 29, 2002 04:44 PM
BeeT
Jun 23, 2001 10:18 AM
