Boost problem
Old Nov 30, 2002 | 04:43 PM
dwilson's Avatar
Default Boost problem
I am running a tial waste gate with a .45 spring in it. I have not bought a boost controller yet and i am regulating boost off the wastegate. My problem or question is, on my Greddy boost gauge (it is rated in bar) I am only seeing it boost to like .35 (5 psi) does this sound right or am i loosing pressure somewhere? Any suggestions on what i can double check? Could it be that my wastegate is adjusted incorrectly and is not regulated to the full .45 that my spring is regulated to?Any help would be appreciated.
Old Nov 30, 2002 | 04:53 PM
syndicate43's Avatar
Default Re: Boost problem (dwilson)
are you running an intercooler you may have a presure drop from that depending on the size
Old Nov 30, 2002 | 04:59 PM
DeepSi's Avatar
Default Re: Boost problem (syndicate43)
where is your vacuum source for the wastegate hooked up to?
Old Nov 30, 2002 | 05:16 PM
dwilson's Avatar
Default Re: Boost problem (DeepSi)
I am running the spearco that comes with the drag kit and the vac.is coming off of the turbo, it is the only thing tied to that source. Boost gauge, BOV, and FPR are all off the intake vac.
Old Nov 30, 2002 | 07:43 PM
CzanSOHC's Avatar
pressure drop from intercooler.
Old Nov 30, 2002 | 10:57 PM
dwilson's Avatar
Default Re: Boost problem (CzanSOHC)
anyone else, is there away to adjust the wastegate to get a couple more psi out of it and if so i guess i would have to have my hondata retuned right.
Old Nov 30, 2002 | 11:31 PM
Dramier's Avatar
I agree with the above. Intercooler PSI drop. Depending on the quality and flow of an IC you lose either a little PSI or a lot. You're going to have to slap an MBC on there that bypasses the wastegate to squeeze anymore PSI out of it. Trust me that it is better to have lower PSI with an IC than higher PSI but no IC. I'd just about give my left nut for an FMIC right about now. (Right one's more valuable.. I guess... )
You usually don't adjust the wastegate to control boost, that's what an MBC is for. Install an MBC and boost guage if you haven't already. I made my own custom one for around $10 bucks, search for my post here in FI on it. Good luck.
ATS*Mark
Mar 18, 2004 06:54 AM
btrim23
Feb 10, 2004 09:02 AM
cnydelSolHybrid
May 31, 2003 05:21 PM
BEV@GSCMotorsports
Apr 30, 2003 06:49 AM
1.8EG-T
Jan 30, 2002 06:54 AM
