fitting on f22b1 block for oil pressure sender???
what sized fitting is used on the 95 accord f22b1 block, i need the fitting that is for the oil feed, on the back of the block, where the oil pressure sender is located at.
someone told me it was 1/8 bspt but i have no clue, and i ned to know so i can get thios oil line kit made already...
ken
[Modified by Superorb, 12:18 AM 11/30/2002]
ken
Re: fitting on f22b1 block for oil pressure sender??? (JDMCRX)
sooo.. what size is the sender...
im having a friend make me the kit, i just need to know the size fitting that goes into the block, and what size the sender is, so it can go into the right sized fitting.
thanks,
ken
thanks,
ken
Re: fitting on f22b1 block for oil pressure sender??? (drift)
Nice to see another F series guy around here.
Heres a pic of mine that I shot during the install. (I retapped the hole to 1/8" NPT and havnt had a prob)
Re: fitting on f22b1 block for oil pressure sender??? (niedejb)
how did u retap it to the 1/8 npt anyways... and will the oil pres sender thread into the 1/8 npt Tee fitting?
Re: fitting on f22b1 block for oil pressure sender??? (Superorb)
Just run the npt tap into the hole in the block.
The pressure sender threads into the npt T well enough with teflon tape.
totsie7944
05-01-2008 04:52 AM
reignofchaos
08-03-2003 10:24 PM
