Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so...
what are you guys doing as far as the fuel pump is concerned...are you guys all running stock in-tanks and an in-line?
you guys w/ standalones and FPR's (no FMU guys)...
Re: Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so... (D16A6Turbo)
You can use a 92+ fuel pump. Just get the fuel pump assembly from a 92+ and you should be able to figure it out, it's not hard.
Auto performance engineering sells a crx specific fuel pump. They have the 190 lph and the 255lph high and regular pressure. I bought the high pressure kit for my crx and it took very little effort to get the pump to fit perfectly in the place of the stock pump. Auto Performance Engineering
[Modified by racerxadam, 12:39 PM 12/1/2002]
Re: Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so... (racerxadam)
i'm running a standalone with the High volume/high pressure Walbro pump from auto performance engineering.
New User
Re: Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so... (Jared)
I've got a Holley upgrade pump for an eclipse GS-T with 550's and a ZDyne Gold...
I also made 232 at the wheels with no leaning out issues.
There's pumps for us out there... you jsut have to look
Re: Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so... (SiR Kid)
i have a walbro 255lph intank
[Modified by sporkcrx, 10:12 PM 12/1/2002]
Re: Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so... (sporkcrx)
yes i am also running a 255 walbro pump along with a adj. fpr, and 440cc injectors, and i run 14psi on a D16y8. But i also run a piggy back computer. Hondata S200 series.
I run a walbro 255 like othere meant for a mustang, I modfied the stock pump bracket. I run over 20 pounds no problem. Jason
Re: Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so... (littlebluecrx)
jason what is the fuel setup in your car? just curious. did you run 9.80 with stock fuel lines?
[Modified by racerxadam, 12:58 AM 12/4/2002]
