Gear dependant boost control????
Old Nov 29, 2002 | 06:51 PM
speed's Avatar
Default Gear dependant boost control????
How does this work and what specifically do I need to have this feature?Who makes something that controls the boost level differently in every gear(ie)1st=5psi,2nd=10psi,3rd=15psi,etc.
Old Nov 29, 2002 | 06:55 PM
tony1's Avatar
Default Re: Gear dependant boost control???? (speed)
Apex avc-r. It's a pain in the *** to get set up, but when you do......
Old Nov 29, 2002 | 07:01 PM
TurboIntegra's Avatar
It is fairly easy to setup.
First setup your gear ratio's. I believe it is in the setup screen somewhere under "gear judge" could be wrong on that.
2nd you adjust your "Start duty" in the gear you want. For example first gear -50% to get traction in first.
It is hard to explain on the interenet off the top of my head, but if you read the directions they are very straight forward.
b16bri
Jan 26, 2012 01:51 PM
kmaz93da
Engine Management and Tuning
Jun 3, 2010 09:27 AM
JBLAZE622
Oct 10, 2008 12:42 AM
dart2.2
Sep 29, 2008 07:38 AM
bootlegcivic
Feb 18, 2005 05:00 PM
