Mssing link??
Old Dec 1, 2002 | 10:46 AM
The Brown Kid's Avatar
Default Mssing link??
Ok i had that fuel cut problem when i was boostin and i heard that there was this thing called the missing link and it would bypass it. Does anyone know where i can get one for my 89 crx ?
Old Dec 1, 2002 | 11:27 AM
inspyral's Avatar
Default Re: Mssing link?? (Iron Flag)
The Missing Link is an aluminum check valve that replaces the typical fishtank type valves that people usually run. I don't see how it would remedy your fuel cut situation. They can be had at importparts.com I think.
Old Dec 1, 2002 | 11:28 AM
inspyral's Avatar
Default Re: Mssing link?? (inspyral)
http://www.importparts.com/importpar...t/View/CHECK01/
Old Dec 1, 2002 | 01:34 PM
Teg4e's Avatar
Missing link helps you avoid check engine lights by the MAP sensing boost rather than the vaccuum an N/A motor would see.
Old Dec 1, 2002 | 03:19 PM
zip's Avatar
zip
You can also use the SMC as a missing link by setting the corrections all to zero. But you can use it later on as a fuel controller when upgrading to larger injectors (440-550cc) when increasing the boost to 1-14psi! The SMC is a two-in-one device.
Old Dec 1, 2002 | 09:50 PM
camp1320.com's Avatar
Default Re: Mssing link?? (zip)
for Zip and the SMC... testing in progress..!!
turboturd98
Dec 24, 2003 07:49 PM
DeL SLo
Jul 20, 2003 11:12 AM
RuthlessEF-9
Dec 8, 2002 01:36 AM
BoostedD15B7
Sep 23, 2002 06:42 AM
tarkus
Jan 23, 2002 10:46 AM
