diy: Downpipe...need help
Old Feb 12, 2003 | 07:01 AM
specie's Avatar
Default diy: Downpipe...need help
I bought a turbo with a 4-bolt flange included. I've been looking at a few pics of downpipes, and it doesn't look like there is too many bends (welds). I already have a 2.5" u-bend I have laying around. I have a friend that welds but he kind of sucks at it. However, I will have to use a handsaw to make all the cuts....is there any cheap alternative to cutting?
Curtis gave me a few quick tips: Use small radius bends and make sure all the cuts are straight. Could you guys give me more tips on making a downpipe? I need one that is A/C compatible. I'm probably going to do a 2.5->3" flare near the oil pan. Where is the cheapest place to get the flare? Is a flex section necessary? When I got my exhaust done, the muffler guy say you can either use flex pipe or springs and bolts when connecting the header (dp) to the muffler.
Could you guys post a couple more pics of your downpipe? (I saw the other post but there were only a couple).
Thanks.
Old Feb 12, 2003 | 07:50 AM
InfamousRS's Avatar
Default Re: diy: Downpipe...need help (specie)
What material are you making it out of?
What type of welder will your friend be using?
I would suggest going to a rental shop and renting a shop (with metal blade) or hand held/portable band saw to do the cuts, it'll make life alot easier!
As for the flex pipe it's something I would do. It takes alot of stress off of the manifold and turbo (from engine motion). You can get a flex pipe from http://www.jcwhitney.com for a fair price.
Old Feb 12, 2003 | 10:02 AM
Brad's Avatar
I used an electric miter saw with a metal blade to make the cuts, but I was looking at this http://www.jcwhitney.com/SearchCatCo...questid=101320 I haven't used it before, but it does look like a cheap alternative. You also could get a flare here http://www.jegs.com/cgi-bin/ncommerc...13&prmenbr=361 but it might be too long if you're doing the flare near the turbo.
Brad
Old Feb 12, 2003 | 11:35 AM
technine's Avatar
Simple, any pipe cutter that can cut your diameter pipe. Cuts within seconds, cheap, no power needed, clean cuts and straight cuts! That's it. Hit up a hardware store.
Old Feb 12, 2003 | 12:19 PM
Jeff C's Avatar
You can borrow an exhaust pipe cutter for Auto Zone...link.
EDIT: Fixed link.
[Modified by Jeff C, 4:20 PM 2/12/2003]
Old Feb 12, 2003 | 12:27 PM
specie's Avatar
Default Re: diy: Downpipe...need help (Jeff C)
Thanks guys.
I'm using the mandrel u-bends (I think it's mild steel) from jegs.com. My friend has a Mig welder.
How well does the exhaust cutter from autozone work? It's free, so I think I'm going to try that first.
Thanks for the inputs.
Old Feb 12, 2003 | 12:33 PM
Jeff C's Avatar
Not sure how it works, but I am going to rent one this weekend.
Full-Race Javier's Avatar
try not to "cheat" bends....u want a tangent cut. u can get a "swedge" or "flare" from almost any muffler shop for next to nothing
Old Feb 12, 2003 | 05:47 PM
specie's Avatar
Default Re: diy: Downpipe...need help (javierb14)
I'm not sure what you mean to "cheat" a bend. So just cut all the pipings perpendicularly...
Old Feb 15, 2003 | 12:52 PM
specie's Avatar
Does the size of the DUMPTUBE (from the wastegate) matter?
Old Mar 23, 2003 | 07:45 AM
tegasaurus's Avatar
back from the dead...
sorry to bring the post back, but im now in the same situation as you and i was wondering how everything went. Any pics of the donwpipe, any problems? where were the cuts made on the U bends to make the downpipe?
Thanks,
Ryan
Old Mar 23, 2003 | 05:13 PM
specie's Avatar
Default Re: diy: Downpipe...need help (tegasaurus)
I bought a new maxrev downpipe for a member on here. It doesn't look like it's too bad to make one though. Just make sure to get the tightest radius u-bends available. If you're in a hurry, I believe an exhaust shop should be able to make one easily. Sorry I couldn't help.
Pr0ject93hb
May 17, 2007 12:36 PM
Pr0ject93hb
May 17, 2007 10:37 AM
Donkey85
Feb 16, 2004 05:01 AM
Blindstuff
Jan 22, 2004 02:25 PM
IntegD
Sep 14, 2002 09:29 PM
