hondata & techedge help
Old Feb 11, 2003 | 08:06 AM
g2turbo's Avatar
Default hondata & techedge help
I was doing some research lately and im still a little confused how to go about configuring the techedge wideband so that hondata can read the V(out) from the WB display and show the values on the hondalogger, romeditor??
the main question is how do you wire up the techedge into the hondata so the hondalogger can datalog lambda rather than narrowband 02 voltage. I do know that you have to switch the car to open loop and configure the voltage/lambda tables. Where can i find these values>? The values on the site only show from .6v to 1.8v? is that the right values?
i read that you can use a multimeter when the wideband is runnign and open up the display and find which wire carries the voltage. then take that wire to pin 14 on the ecu. But then wouldnt you have to unhook that wire when you wanted to hook back up your stock o2 sensor and run closed loop again.
also when you use the wideband sensor do you just unplug the stock sensor and then plug the wideband into the stock harness. I read on the hondata site they can give you an adapter using the plug off a dead o2 but where does this go. do you cut the plug of the ntk L1H1 and put this plug on.
hopefully someone can clarify all of this.
thanks. CHRIS
Old Feb 11, 2003 | 10:29 AM
g2turbo's Avatar
Default Re: hondata & techedge help (g2turbo)
bump
Old Feb 18, 2003 | 06:22 AM
g2turbo's Avatar
Default Re: Hondata & Techedge help (g2turbo)
anybody??
Old Feb 18, 2003 | 06:41 AM
Doodoo's Avatar
try this thread, it is hard to find by searching. It answered my questions after re-reading it.
https://honda-tech.com/zerothread?id=372768
Old Feb 18, 2003 | 06:48 AM
racerxadam's Avatar
https://honda-tech.com/zerothread?id=352684
https://honda-tech.com/zerothread?id=334920
https://honda-tech.com/zerothread?id=292596
Old Feb 18, 2003 | 11:42 PM
1.8T_EG's Avatar
Default Re: Hondata & Techedge help (racerxadam)
... great info here...
Old Feb 19, 2003 | 04:28 AM
g2turbo's Avatar
Default Re: Hondata & Techedge help (1.8T_EG)
thanks guys!
Jeffro1265
Aug 17, 2010 12:05 PM
GSROWNSU
Mar 24, 2008 12:52 PM
mike93eh2
Oct 1, 2006 06:09 PM
turtle-eg
Mar 13, 2005 10:14 AM
hybrid901
Aug 23, 2003 06:52 AM
