Sohc turbo maifold on a dohc?
Is it possible to redrill the bolt pattern from the dohc engine to the sohc turbo manifold? I'm just trying to save some cash.
Re: Sohc turbo maifold on a dohc? (UNDER PRESSURE)
You searh now UNDER PRESSURE-san. Yes it is possible. However you'll probably put 500 dollars in man hours into it making it work.
Re: Sohc turbo maifold on a dohc? (trboCIVIC&WRX)
I'm pretty sure I could go at it with dremel.....(I did use the search)
[Modified by UNDER PRESSURE, 4:41 PM 2/11/2003]
Why use a manifold designed to for SOHC exhaust flow on a higher flowing DOHC? You'll only choke the motor trying to save a few bucks.
Get it right the first time so you won't be back here complaining that you blew something up.
speedehatch
02-12-2004 02:49 PM
egturbo
48
01-19-2003 06:24 PM
