Piston Ring Question
Old Feb 11, 2003 | 03:57 PM
turboteg96's Avatar
Default Piston Ring Question
What kind of piston rings would you guys use when going forced Induction. Is stock OK or is it not as good as another brand. I will be using the stock pistons and bore.
Opinions welcome,
Old Feb 11, 2003 | 04:30 PM
genop's Avatar
Default Re: Piston Ring Question (turboteg96)
If you are going to stick with the stock pistons, I would just use stock rings. Although depending on how many miles you have on the motor you might want to do a little rebuild before going turbo (rings, seals, bearings, gaskets). It would probably extend the life of the motor quite a bit......
Old Feb 11, 2003 | 06:42 PM
turboteg96's Avatar
Default Re: Piston Ring Question (genop)
well, I planned on getting new rod bearings, valve seals and piston rings. I was just wondering if an aftermarket set would be better than OEM for replacement.
Old Feb 11, 2003 | 06:48 PM
genop's Avatar
stock should be fine in your case. Just remember, dont buy total seal......
turboman2.2
Feb 10, 2010 10:45 AM
Ls4thGen
Apr 27, 2005 09:41 AM
BlwnBlue
Aug 13, 2001 05:55 AM
rioninja
Jul 31, 2001 05:37 PM
