... fuel system upgrade... 300-350whp...
goal:
- 300-350whp
setup:
- b18c1 (stock sleeves)
- 9.8:1 je pistons
- eagle rods
... what fuel system upgrades would i need to achieve my goals?... i am guessing adjustable fuel pressure regulator (b&m, aem, aeromotive)... is this necessary, or will the stock fpr hold?... also, is there anything else i should consider upgrading?... lemme know... thanks in advance...
- 300-350whp
setup:
- 9.8:1 je pistons
- eagle rods
Re: ... fuel system upgrade... 300-350whp... (1.8T_EG)
I make 325whp on the street at 10psi and 390whp on C16 at 16psi.
I use a Vortech 12:1 FMU, missing link, RC 440cc injectors, SAFC, 255lph intank pump, stock fpr. The car runs fine. I am stepping up to a aeromtive 500lb/hr pump and -10an lines though. 330whp is about the most you can get safely on pump gas out of my current setup.
Re: ... fuel system upgrade... 300-350whp... (EF9_SiR)
yep -10 an is gonna be pushing alot of fuel, but were shooting for aroun 550whp on race fuel. You can use your stock return line to try and keep fuel pressure stable.
Not sure what my fuel pressure is at.
Re: ... fuel system upgrade... 300-350whp... (autoEXturbo)
autoEXturbo - are you running the afc hack with a fmu and missing link? doesnt the hack get rid of the missing link and fmu?
All you need is a walboro 255lph fuel pump, 720cc injectors and hondata. You dont need any aftermarket fpr's, fuel rails, lines, etc. Your duty cycles will still be around 60-65% at 350whp, so you still have room to expand.
autoexturbo i would like to ask u a few questions about your setup. 1st what size turbo are u runing because i was thinking about runing a t3/t04e. also what do u think of the thermal exhaust system. and lastly are u runing a stock block or a built bottom end
Smarter than you
I run stock fuel lines, stock fuel rail, and stock fpr. only upgrades are rc 550cc injectors and walbro intank fuel pump. im already near 300whp and there is plenty room to go.
Re: ... fuel system upgrade... 300-350whp... (eagle2)
Pretty much junky. The only reason you should want a fpr is to turn down your fuel pressure with really large injectors. If you need to turn up the fuel pressure, than get larger injectors. You cannot turn down your fuel pressure with the b&m. I am running the stock fuel rail, fpr and lines for around 450whp.
Topdawgg
11-24-2006 05:15 PM
Brian_92GSR
10-25-2001 11:27 AM
