Please help, I'm stumped!
Old Feb 13, 2003 | 05:48 AM
bQQsted hybrid's Avatar
Default Please help, I'm stumped!
Okay, here's the situation:
I start the car and it has trouble idling. It kinda sputters/misses. I try to keep blipping the throttle to keep the RPM's up, but at soon as the RPMs reach 2.5k - 3k the car tries to shut off. The dash lights will flicker on/off, and the AVC-R will keep turning on and off...kinda like the car is turning on/off very quickly. After it does that for a while the car will eventually die.
I haven't driven the car for a few months, but I went to my parent's house to start it up every now and then. Compression and everything was fine before I parked it.
Here's the other wierd part, it did this with the stock injectors, and stock ignition with a MSD blaster SS coil. I just changed the setup to DSM 450's, SMC plus, MSD BTM w/ Blaster SS coil, and it's doing the same exact thing!
I replaced the rotor, wires and plugs. All of the engine grounds are fine. My battery is on it's way out, but I don't think that's it.
Does anyone have ANY ideas?
Old Feb 13, 2003 | 06:16 AM
boosted hybrid's Avatar
Default Re: Please help, I'm stumped! (bQQsted hybrid)
I had this same situation when my eeprom chip in my hondata was loose. Sounds like a bad ground, or possible something ecu related. I'd check all electrical connections, and if you are running hondata check your eeprom chip.
Old Feb 21, 2003 | 05:24 AM
Default Re: Please help, I'm stumped! (boosted hybrid)
I finally got around to checking the car out.
I checked all the grounds and everything looks OK. Can any of this be caused by the main relay? One time after the car died, there was a LOUD buzz from the main relay. Now I noticed that when I turn the key to the accessory position, there is a constant audible clicking coming from the main relay.
I don't think that the symptoms that I'm having is common with a bad main relay though. I'm going to switch it out today to check.
Any ideas?
Old Feb 21, 2003 | 05:31 AM
Tinker219's Avatar
well, check the fuses for one...
I had a car sit outside all winter, and when i went to start it come spring, nothing happened. A mouse got inside my dash and had a hayday with the wiring...I was pissed...
other than that..um...try getting a new battery. You might be surprised at what that can do...
Old Feb 21, 2003 | 05:35 AM
i3oricua's Avatar
Default Re: Please help, I'm stumped! (Tinker219)
Get your alternator checked. Do you have a battery light come on when the car is running? Just trying to throw another possibility at ya.
Old Feb 21, 2003 | 05:36 AM
Tinker219: I already replaced the battery and checked the fuses. Is there anything else i should check, or should I just push this thing off of a bridge? maybe a mouse got into my wiring too.
i3oricua: the battery light doesn't come when the car is running, i'll check the alternator though.
[Modified by bQQsted hybrid, 6:38 AM 2/21/2003]
Old Feb 21, 2003 | 05:43 AM
RGAZ's Avatar
New User
Possible faulty ignition switch. Mainrelay will click/chatter based on the ignition switch.
One more variable in the equation.
Randy
Old Feb 21, 2003 | 05:44 AM
Tinker219's Avatar
i take it the car was running with the smc and 450s and all that?
if not, timing could have slipped...
bad plugs? Ive had plugs just "go bad"...
95blackEG
Dec 24, 2008 07:59 PM
patrick4588
May 2, 2006 11:41 AM
_Endless_
Jan 23, 2003 05:05 PM
Charlie Moua
Aug 2, 2002 04:50 AM
