Please help ASAP Gap for spark plugs??
Old Feb 12, 2003 | 05:23 PM
Drew Peacock's Avatar
Default Please help ASAP Gap for spark plugs??
Hi guys I have just got new plugs for my boosted sohc I run 8psi daily and upto 11psi at the track (not often) the plugs are NGK BCP7EV just wondering what the correct gap for them is?? Is it .32 or less?? Cheers
Old Feb 12, 2003 | 05:32 PM
turbod16y8's Avatar
Default Re: Please help ASAP Gap for spark plugs?? (turbozxi)
.032-.034
DRAGLS's Avatar
.032 is good
Old Feb 12, 2003 | 05:36 PM
Default Re: Please help ASAP Gap for spark plugs?? (DRAGLS)
So .32 will be good even at 11psi?? Thanks alot
Old Feb 12, 2003 | 05:38 PM
DRAGLS's Avatar
it's a good place to start if you feel any misfiring go down some more.
Old Feb 12, 2003 | 05:41 PM
Thanks is misfiring quite easy to pick out?
Old Feb 12, 2003 | 08:43 PM
Yeah gapped to .32 and it is misfiring at only 8psi.... Now I am going to try .30 will post up how it go's incase anyones interested!
Old Feb 13, 2003 | 12:53 AM
boostaholic's Avatar
You probably know this, but some people don't so i want to make sure so they don't get the wrong idea. Go with a .030-.035" gap on the plugs, .32" is a big difference from .032". It's a hell of a lot bigger when gapping plugs.
Old Feb 13, 2003 | 05:19 AM
zojirushi's Avatar
Default Re: Please help ASAP Gap for spark plugs?? (boostaholic)
how can you tell if your car is misfiring? loud popping noises upon acceleration?
[Modified by zojirushi, 9:20 AM 2/13/2003]
Old Feb 13, 2003 | 05:43 AM
Boost2NA's Avatar
Default Re: Please help ASAP Gap for spark plugs?? (zojirushi)
yeah basically if you go to big the car will miss pretty bad. Easiest way to describe this is basically just spitting and sputtering under boost. Basically if the gap is to big and your ignition is not strong enough the boost will actually blow the spark off the plug resulting in missing.
Old Feb 13, 2003 | 08:28 AM
swrdply400mrelay's Avatar
Default Re: Please help ASAP Gap for spark plugs?? (Boosted99Si)
Will that sound like the same sputtering if you're running too rich? I get that when I boost at 8psi also, so I'm not sure which one it is.
dyeahdj
Mar 14, 2012 04:39 PM
intek_gsr
Sep 26, 2002 10:21 AM
ALLMOTOR18
Sep 10, 2002 03:05 PM
DamnSlowCivic
Apr 15, 2002 07:29 AM
