Good size turbo
Old Feb 11, 2003 | 03:38 PM
cr-x si's Avatar
Default Good size turbo
I am going to make a custom turbo for my zc. And i was wondering what cars i should look for at the junk yard that will have a good size turbo for my setup? I want to run around 6-12 psi. Any suggestions?????
Old Feb 11, 2003 | 06:25 PM
cr-x si's Avatar
Default Re: Good size turbo (cr-x si)
BUMP
Old Feb 11, 2003 | 06:34 PM
b16ahybrid's Avatar
Saab's have a t3 that would work pretty good, volvo's, and i believe the mustang has a larger t3 not sure on the specs. Check my sig....
Old Feb 11, 2003 | 06:44 PM
*Boostwerks*'s Avatar
The best junk yard turbo I have found to be, is the 1st gen DSM 14B.
The T-25 is a little to small, and kills top end.
I do not have too much info on the Saab/Volvo T3's, so I can't help you there.
Here is my "How to" article to turbo a ZC....
http://www.thezcresource.com/html/jnkyrdturbo.php
Happy boosting...
Old Feb 11, 2003 | 06:58 PM
b16ahybrid's Avatar
Default Re: Good size turbo (Bryson)
I know the chrysler and saab use a .48 on the exhaust side and a .42 on the compressor side.
Old Feb 11, 2003 | 07:08 PM
M.A.R.C.'s Avatar
Default Re: Good size turbo (b16ahybrid)
I know the T3's off ford thunderbirds were like
60 trim .60 a/r compressors| stage I wheel and .48 a/r turbine (auto) and .63 turbine (manual)
Old Feb 11, 2003 | 07:51 PM
Joseph Davis's Avatar
Default Re: Good size turbo (CivicRyda2k)
CivicRyda2K's pointer toward the Ford T3's would be the way I'd steer you. The DSM TD04 and the Saab .42 trim are both on the small side, support 200-220 hp before you start overspinning them.
The Ford T3's are .60 trim compressors, good for 300 crank hp, and can be found on any of the 84-86 Ford 2.3 turbos. Be careful of the 87-88 Thunder Chicken - they got IHI's that are smaller than the aforementioned TD04/.42 trim T3s.
Old Feb 11, 2003 | 07:54 PM
yellowsub's Avatar
Default Re: Good size turbo (J. Davis)
The 14b will support a lot of power. They put big heavy dsm's into the 12's.
Old Feb 12, 2003 | 04:01 PM
cr-x si's Avatar
Default Re: Good size turbo (yellowsub)
sweet thanks for the info
Hector Conde
Aug 28, 2015 02:55 AM
MooreBoost
Sep 13, 2004 02:37 PM
allmota1.8
Oct 21, 2003 06:42 PM
turbohf
Mar 14, 2003 08:28 AM
*Boostwerks*
Sep 9, 2002 10:01 PM
