Injector pic need help
Old Feb 12, 2003 | 03:21 PM
DRAGLS's Avatar
Default Injector pic need help
Modified by DRAGLS at 7:29 PM 1/5/2007
Old Feb 12, 2003 | 03:39 PM
Tinker219's Avatar
Default Re: Injector pic need help (DRAGLS)
they might fit if you got a smaller oring at the top(that one might work), and mess with the lower part of the injector(double up on stock rubber seals) Other than that, the only limiting factor that I can see is height issues, which can be solved with washers/longer fuel rail studs.
Old Feb 12, 2003 | 03:45 PM
Tinker219's Avatar
If it was me, id try it I think below that is just the fuel tube, i doubt there is anything sensitive about it. Just make sure its a clean cut, and dont cut into the tube...
one more thing...try cutting one groove at a time till it fits...
Old Feb 19, 2003 | 12:26 PM
GRTechnologies's Avatar
your going to have to drill the rail out, if you dont you will probley get a leak
slammedbbs
Jul 6, 2011 02:52 PM
Sic_DA_Nine
Mar 1, 2008 05:26 PM
Homesickelian
May 17, 2006 10:02 AM
eddyboy
Jan 14, 2005 10:40 AM
Toptul_Honda
May 23, 2003 02:12 PM
