Need to upgrade brakes...Suggestions????
I need to upgrade my stock brakes on my '99 Si. I need something that will fit under my stock 15's, but most importantly I need them to fit under my 13 inch Bogarts. I was thinking of keeping the stock calipers and upgradeing the pads with some Hawks or Padgets. As for the rotors there seem to be many options out there, although which to choose. I was thinking of using Brembo crossed drilled, although they don't come drilled from Brembo. Who's using crossed drilled Brembo's, and what do you think of them?
Also any suggestions would help.
Or better yet list your setups.
Thank's, David.
Thank's, David.
Re: Need to upgrade brakes...Suggestions???? (turbo Si)
i sued the powerslot with some porterfield r4s brake pads and they worked great.. cheap alternative to the larger upgraded pacakages.
Re: Need to upgrade brakes...Suggestions???? (b18bturbo)
Stainless lines (Goodrich)
Porterfield R4S pads (or axxis ultimates, hawk hp+, or something similar)
Motul 600 fluid or ATE blue.
Brembo blanks
Stock calipers
That's a proven recipe for much better braking without putting too much of a hurt on your wallet.
Tom
Brembo blanks
Stock calipers
Tom
Check out fastbrakes drag brake kit upgrade. I have the 11.5" 4 pistons wilwood's up front with 11.5" upgrade in rear. Stops on a dime.
use panther plus pads up front and axxis ulitmates on rear I use them in track events boy do they grip like a **** makes the stockys feel like they dont even work lol the enital bite is awsome
Re: Need to upgrade brakes...Suggestions???? (boosted hybrid)
Re: Need to upgrade brakes...Suggestions???? (Tomakit)
[QUOTE]Stainless lines (Goodrich)
Brembo blanks
Stock calipers
on your wallet.
Where can I find Porterfield Pads?? What about the crossed drilled Brembos?
Brembo blanks
Stock calipers
on your wallet.
The fastbrakes drag brake kit is specifically meant for 13" drag wheels. Check it out http://www.fastbrakes.com.
I was on there earlier in the day although none of the systems had info, that i saw atleast, on what size wheels there applications will fit. I also called and left a message for Brian, I belive, so I wait till he call me back. They have some nice stuff though.
KLackeyImages
12
01-26-2022 07:54 AM
