inline pump....12v? toggle?
Old Feb 12, 2003 | 09:11 PM
ridnmyhonda's Avatar
Default inline pump....12v? toggle?
what should i do for my lnline pump? should i just run it to a 12v source like the ignition wire? or should i run it to a toggle switch so i can turn it off and on? also when the pump gets turned off what does that do? stop fuel or does it let fuel flow and just not pump it?? thanks
Old Feb 12, 2003 | 09:38 PM
Default Re: inline pump....12v? toggle? (ridnmyhonda)
do i wire this up to 12v or do i have to do the relay route...please somebody help i cant get this thing in...thanks
Old Feb 13, 2003 | 01:17 AM
havok hybrid's Avatar
i just hooked mine up without a switch .. to the ignition wire.. works fine.. No reason to turn it off and run off stock pump...
Old Feb 13, 2003 | 01:21 AM
boostaholic's Avatar
Just run a standard automotive 30amp fuse and wire the signal wire from the stock pump to it. That way when ever the stock pump gets power so does the inline pump.
Old Feb 13, 2003 | 09:18 AM
RAWB's Avatar
I ran a toggle switch inline with the 12v wire(to inline pump) that is tapped off of 12v ignition switch. This gives me the ability to turn off my inline when at cruising speed and gives me a "positive indication"(lights up) that my inline is on when boosting, as well.
Old Feb 13, 2003 | 10:15 AM
Overblown-Teg's Avatar
Default Re: inline pump....12v? toggle? (RAWB)
We ran ours off a 5psi hobbs switch and ran a red light on the dash to show when it has power.
Old Feb 13, 2003 | 04:23 PM
Cramerox's Avatar
Default Re: inline pump....12v? toggle? (boostaholic)
or you can use this diagram for a relay (arturbo) Goes under the dash so you dont need to run a line all the way to the back seats.
[Modified by Cramerox, 5:25 PM 2/13/2003]
00trdtaco
Audio / Security / Video
Aug 20, 2009 09:42 AM
00trdtaco
Aug 20, 2009 06:42 AM
Civic Si Kid
May 17, 2009 12:26 PM
sCeRaXn
Sep 13, 2003 12:14 PM
B18C-RnVA
Dec 27, 2002 06:26 PM
