wiring accessories with standalone?
Old Feb 12, 2003 | 12:14 PM
paulzy's Avatar
Default wiring accessories with standalone?
HOw would you wire ascessories with a stadnalone?
example:
headlights
turn signals
brake lights
ignition
alternator
speedometer
Would I need a new fuse Panel(box)for the standalone?
How have you guys done it?
Old Feb 12, 2003 | 12:16 PM
b18bturbo's Avatar
Default Re: wiring accessories with standalone? (Paul_Vang)
all that should be with your factory harness. all you really need to do is just run the power to it . with fuse box.
Build a fuse panel
Old Feb 12, 2003 | 12:29 PM
boosted hybrid's Avatar
Default Re: wiring accessories with standalone? (b18bturbo)
I ran the factory wiring with a fuse panel when i ran haltech.
Old Feb 12, 2003 | 12:36 PM
boostaholic's Avatar
Default Re: wiring accessories with standalone? (boosted hybrid)
Only thing i wired up manually was the speedo and tach. Lights, signals, etc. are all tied in with the stock wiring and fuse panel. Speedpro controls everything else.
Old Feb 12, 2003 | 12:52 PM
paulzy's Avatar
Default Re: wiring accessories with standalone? (boostaholic)
so you run run a power wire from teh fuse box to the ECU? or do you tie in teh fuse box with teh ECU?
Old Feb 12, 2003 | 03:34 PM
paulzy's Avatar
ttt for answer
Old Feb 12, 2003 | 06:22 PM
With the Speedpro, the stock fuse panel runs independent of the ECU and vise verso. The Speedpro harness has its own fuses built in.
fatsalmon15
Audio / Security / Video
Apr 10, 2014 06:44 AM
recaroem2
Honda Civic (2001 - 2005)
Nov 5, 2008 01:58 PM
dublebuble
May 20, 2007 10:04 PM
GreenD16Y8
Aug 8, 2005 03:59 PM
