compressor on driver side..advantages?
Old Feb 13, 2003 | 01:14 PM
DefiantGSR's Avatar
Default compressor on driver side..advantages?
excuse my ignorance...but what are the advantages of having the compressor on the driverside? thanks
Old Feb 13, 2003 | 01:15 PM
B18EG6's Avatar
Default Re: compressor on driver side..advantages? (DefiantGSR)
One advantage is a nicer, easier to make downpipe...i think.
dunno though
Old Feb 13, 2003 | 01:36 PM
Full-Race Geoff's Avatar
-easier to run a 4" inlet turbo
-easier to fit a filter
-smoother bends in the downpipe
-the compressor inlet wont suck in hot air from behind the radiator
-dump compressor outlet directly to intercooler end tank (no piping)
Old Feb 13, 2003 | 01:39 PM
DefiantGSR's Avatar
Default Re: compressor on driver side..advantages? (FFgeoff)
wow, thanks geoff.
any disadvantages?
[Modified by DefiantGSR, 10:42 PM 2/13/2003]
Old Feb 13, 2003 | 01:46 PM
Phoenix GSR's Avatar
yeah, no AC
*Boostwerks*'s Avatar
I would keep in mind that this is a 92+ civic and teg chassis.
The space in the CRX's, and early civics is by far limited.
Old Feb 13, 2003 | 01:57 PM
Sonny's Avatar
25 Year Member
Default Re: compressor on driver side..advantages? (Bryson)
Nah, there's lotsa room in the 1st gen CRX.
In the 2nd gen, they used that huge *** front crossmember. You're kinda hosed by that thing.
Sonny
Old Feb 13, 2003 | 03:00 PM
Zero_son's Avatar
Default Re: compressor on driver side..advantages? (Sonny)
Sonny
Wouldn't a Jimfab unit eliminate this problem?
Old Feb 13, 2003 | 03:02 PM
Sonny's Avatar
25 Year Member
Default Re: compressor on driver side..advantages? (Zero_son)
Yep, it sure will...it will also lighten your car because your wallet will be a lot lighter.
Sonny
Old Feb 13, 2003 | 10:10 PM
Thats not really the problem....
The problem is that there is less overall volume between the engine, front of the radiator, and sides of the chassis to mount a turbo and air filter.
with this setup:
-4gen CRX/EF
-ZC motor
-Sparks racing manifold
- Precision SC32, mounted with compressor on drivers side
- APexi filter
There is about 3-5mm of space between the air filter and the chassis...
There is plenty of space for a 3" downpipe with my JimFab however
prime-R
Jul 3, 2010 04:42 AM
Turbo E
Aug 8, 2006 08:59 AM
teddy_dc2
Dec 11, 2005 12:28 PM
sneakypete
Jul 16, 2003 10:43 PM
