max rev diy piping
Old Feb 10, 2003 | 07:29 PM
redline201's Avatar
Default max rev diy piping
i cant find the thread anymore but...
i think ive read the max rev diy intercooler piping is incomplete
does anyone know what other piping is needed?
i was looking at jc whittney but i am unsure what i need
anyone know???
thanks
Old Feb 10, 2003 | 07:38 PM
Anubyss's Avatar
Default Re: max rev diy piping (redline201)
You shouldn't need to buy any piping. It's just you have to cut and weld them together. At least I didn't need anything.
Old Feb 10, 2003 | 07:39 PM
Smashback's Avatar
What bends and how many of each did it come with?
Old Feb 10, 2003 | 08:08 PM
Pat's Avatar
Pat
Default Re: max rev diy piping (Hatchblack)
I think you would need a long straight piece to make an upper charge pipe. The piping I got don't seem to have that included. I got 5 90deg bends and 1 45deg bend
Old Feb 10, 2003 | 08:41 PM
redline201's Avatar
Default Re: max rev diy piping (Pat)
thats what i mean
im thinking i need somthing for the charge pipe
do i need aluminum or steel piping ???
i found some at jcwhittney.com
Old Feb 10, 2003 | 09:27 PM
Smashback's Avatar
Honestly, what you'll probably do is this...
1 90 from the turbo
2 90s around the radiator suppor and into the ic
2 90s out the ic and back into the engine compartment
1 90 up from this pipe, angeled about 45 deg towards back of car
1 45 from here towards back of car
1 90 from here to tb
make sense? very detailed eh... i don't think you'll need extra, more than likely you'll have enough extra straight pipe from cutting the pieces that you'll be able to make your upper charge pipe without welding two straights together between any of the bends...does that also make sense? eeehh...
Old Feb 10, 2003 | 09:34 PM
Smashback's Avatar
Here's a very professional artistic rendition of what I described. You'll have to use your imagination to cut and angle the upper ic pipe, but it's not that hard.
Old Feb 10, 2003 | 10:07 PM
red_sir's Avatar
I only got 6 pipes though.
Old Feb 11, 2003 | 02:14 AM
civicguy's Avatar
Default Re: max rev diy piping (red_sir)
ttt
Old Feb 11, 2003 | 04:25 AM
Smashback's Avatar
Well then, what angle and how many did you get? Damn....I must be a genius since I didn't buy a "kit" and did all my original work with a hacksaw
Old Feb 11, 2003 | 05:34 AM
redline201's Avatar
thanks for that picture that really helped alot
anyone else have experience with this piping
thanks guys
Old Feb 11, 2003 | 08:01 AM
Smashback's Avatar
Here's some pics of when I did the SOHC...DOHC isn't done yet.
During this period I was experimenting with paint ... ... finally decided on metallic silver (not pictured). Just a disclaimer so I don't get ragged on for having rainbow pipes!
Old Feb 11, 2003 | 11:32 AM
Foozball26's Avatar
hahah chris likes the rainbow pipes
He hides the pink ones so only he can see them when he works on the car.
Old Feb 11, 2003 | 02:56 PM
01ITR#700's Avatar
Default Re: max rev diy piping (foozball-26)
I'm not much help but a friend of mine that got the Max Rev IC and piping needed atleast an additional 1-2 Complete ubends in order to pipe his GSR.
M
Old Feb 11, 2003 | 04:30 PM
Smashback's Avatar
If you come over and help with Antwaine's swap then I'ma sneak some pink paint in on your car somehwere
Old Feb 11, 2003 | 05:04 PM
ASHY-ELBOW's Avatar
got to justinco's site he did a great job on all the detail and pics he put into his site take a look he has pics of how he did his ic piping in here
http://repo.jackmoves.com/view_album...album83&page=2
Old Feb 11, 2003 | 05:06 PM
Foozball26's Avatar
Default Re: max rev diy piping (1320racing)
lol better not, then people will think im a follower of you
Old Feb 11, 2003 | 07:40 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I only got six cheap ole 180 degree, Mild steel U bends from the MaxRev kit.
I'm not going to even use it considering how easily it rust. I'm goign to buy some Aluminized Steel U-bends from JCwhitney.com. It's only about 13.95 per pipe and if you already have cold air intake, you don't even need THAT many pipes.
I'm getting 4 pipes from them. Only need 3 but I'm getting four just in case.
Old Feb 11, 2003 | 07:42 PM
Smashback's Avatar
Default Re: max rev diy piping (Snafu-Si)
You do know that the Maxrev ones are aluminized, right? I'm sure theirs come from JCW also, they are both Imco brand.
Also, damn, that guy with the picture album has some scary *** pipes!! Not trying to dog him but that upper IC pipe kind of ... I dunno. Not the best way to do it.
Old Feb 11, 2003 | 07:47 PM
ASHY-ELBOW's Avatar
says on there web site its stainless ? they stop giving that?
turbo piping b series
Availability:ships in 24-48 hrs
PROD# B161820dyipkg $399.00
Quantity:
This is a do it your self piping pkg the kit is made from 304 stainless steel mandral bent 90's and 45's it comes complete with hose couplers and clamps the kit does require cutting and fitting the pkg is supplied with enough materials to do any b series or h series motor in any of the standard cars with or without engine swaps welding is also and option if you do not want to use all of the hose and clamps
Old Feb 11, 2003 | 08:37 PM
Snafu-Si's Avatar
Well, that's different. I bought my MAXREV kit LAST APRIL of 2002!!!! My didn't come with stainless. ..
Maybe.. I should have waited.
I should have waited for the Hondata also.. next thign I know, there's this freakin S200 model now. Geez.
Old Feb 11, 2003 | 09:08 PM
red_sir's Avatar
I got 5 @ 90 degrees, and 1 @ 45 degree. It seems most other people only got 6 pipes too.
Smashback's Avatar
Yeah maybe the stainless is new, but unless they are REEEALLY cheap, you should have gotten aluminized mild steel, not bare steel.
If you got 5/90 and 1/45 then you should get either:
A: 2/90 deg steel
B: 1/90 deg silicone 1/90 deg steel
C: 1/90 deg steel 1/45 deg steel
D: 1/90 deg silicone 1/45 deg steel
You really need to look at it and use a little caliper or something to help you determine which bends to get. Remember, the less bends the better, so if you can use 180's around the sides, that's better than 2 90's on each side.
[Modified by Hatchblack, 6:11 AM 2/12/2003]
Old Feb 12, 2003 | 12:13 AM
Midwestrider's Avatar
Will this help you guys out...
https://honda-tech.com/zerothread?id=229356
Hope that helps!!
Old Feb 12, 2003 | 10:03 AM
Snafu-Si's Avatar
Default Re: max rev diy piping (Midwestrider)
That is a great link. I have that place on my fav list. helps a lot of what I still might need to do.
yeah though, I think I'm goin to just order the aluminized piping later today. Since I already have Cold Air intake, I was told that I don't need as many pipes as I would normally. And according to that link. I technically only need about 3 180degree u bends. I might just get 4 u bends just in case. couldn't hurt, and won't be a bitch if I find out I acutally need more pipes you know?
