Friday is a big day!!
Old Feb 11, 2003 | 10:05 PM
J.R.'s Avatar
Default Friday is a big day!!
This friday, I will be picking up my revhard stage 2 turbo kit, so I will be in the forced induction forum more often. I have a couple of questions for you guys though,
1 After I get it installed would it be safe to drive it daily even though it isnt tuned? 2 If not, what will I need to tune it other than a standalone?
3 what injectors do you guys recomend, my goals for now are 220-250 whp
thanks guys
Old Feb 11, 2003 | 11:25 PM
J.R.'s Avatar
Default Re: Friday is a big day!! (96b18c1vic)
cmon guys
Old Feb 12, 2003 | 12:06 AM
boostaholic's Avatar
If you just have the revhard kit than it will be using a vortech fmu more than likely. Not much to tune with and you should be relatively fine out the box with 6-8psi on stock injectors, any more and i would atleast get some bigger injectors. To be safe you should retard your timing 2-4 degrees depending on how it runs. Good luck and happy boosting.
Old Feb 12, 2003 | 09:30 AM
J.R.'s Avatar
Default Re: Friday is a big day!! (boostaholic)
cool, so as long as I keep at 6psi, I dont have to tune it for a while. I plan on getting it tuned eventually, just have to save more money. So would you guys recomend taking it easy on for the first hundred miles? Can I get on it out of the box, even though its not tuned? thanks guys
Old Feb 12, 2003 | 01:06 PM
J.R.'s Avatar
bump
noogin
Jul 14, 2013 07:36 PM
TurboEM1
Dec 29, 2006 12:54 PM
civictypenos
Aug 30, 2003 06:00 AM
sianlogic
Jun 23, 2003 05:24 PM
ksoze1688
Sep 8, 2002 03:28 PM
