oil feed line help
Old Feb 12, 2003 | 12:40 PM
B20-T's Avatar
Default oil feed line help
i am running a t3/to4e 60trim .63 ar garret turbo what should i run for the oil feed line a -4 or -3 and what fitting size should i use -3 or -4 i basically gotta redo my whole oil feed line.thanks
Old Feb 12, 2003 | 01:12 PM
mos's Avatar
mos
Default Re: oil feed line help (B20TURB0)
This has probably been covered like twenty times, but some people have said that -4 is too large, and can cause problems with too much oil pressure/volume for the turbo/turbo seals. -3 seems like the safer choice.
Old Feb 12, 2003 | 03:01 PM
B20-T's Avatar
Default Re: oil feed line help (mos)
So use a -3 line?and -3 fitting and nipples?
Old Feb 12, 2003 | 03:04 PM
Tinker219's Avatar
yup thats what hes saying...although i got a t4 off of a John Deere, and it came with a -4 an feed fitting. I wonder if the oil pressure is the same as the GSR pump that Im going to be using....
velisma
Jul 20, 2010 01:18 PM
vantta
Aug 23, 2009 11:54 AM
sampol999
Sep 3, 2006 01:09 PM
MotorMouth
Mar 20, 2006 07:12 PM
oz`Vtec
Jun 9, 2004 07:26 AM
