Which Precision Turbo??
Old Feb 12, 2003 | 01:06 PM
95c1v1cs1's Avatar
Default Which Precision Turbo??
Heres what i got...
ENGINE
B18C
Crower Rods
JE 9.0:1
Block guard
ARP head studs
ferrea valves oversized
polished w/ knife edged crank
Skunk2 intake manifold
stage 4 clutchmaster
balanced and BP
Full 3"
FUEL
AEM fuel rail w/ gauge
Walboro 255
AEM FPR
Coming...
Hondata s200 w/Boost option, 720cc injectors, and stage 3 axles
I will be running 14psi daily . I have a GSR tranny, Quaife LSD, and Drag radials. I might up the boost on trackdays a bit (18psi max).
TURBO CHOICES SC50 or SC34. (please specify A/R)
redline-- 8200
weigh -- 2300lb
Thanks Again for the help -- Corey
[Modified by 95c1v1cs1, 4:12 PM 2/14/2003]
Old Feb 12, 2003 | 01:22 PM
turborex's Avatar
Default Re: Which Precision Turbo?? (95c1v1cs1)
I just ordered the SC60 with a .63ar rear. Should make some good power!!!
Old Feb 12, 2003 | 02:03 PM
*Boostwerks*'s Avatar
I would go with the SC34. .63AR.
will Spool quick, yet won't limit your capabilities.
Old Feb 12, 2003 | 07:25 PM
95c1v1cs1's Avatar
Default Re: Which Precision Turbo?? (Bryson)
I know that some of you already posted to help me. If you still feel the same way about the turbo you picked please let me know. I know I changed a few things around since i posted last including the hondata and 720cc's.
If you need to know anything else to better help me out with my decision, please let me know.
Thanks
Edit: Grammer
[Modified by 95c1v1cs1, 4:26 AM 2/13/2003]
Old Feb 12, 2003 | 08:41 PM
95c1v1cs1's Avatar
Which turbo would give me max. Efficency for 350 hp?
Old Feb 12, 2003 | 10:26 PM
rOby's Avatar
u should be goin for 600 whp club ..hhehe jk
sc 50
Old Feb 12, 2003 | 10:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Which Precision Turbo?? (rOby)
I like the SC34 with a 63 A/R. Let me know if you need one.
art
Old Feb 13, 2003 | 06:43 AM
LEON's Avatar
Default Re: Which Precision Turbo?? (Arturbo)
How quickly does the SC34 spool (.63 a/r) on a gsr?
Old Feb 13, 2003 | 07:42 AM
dmecarboy's Avatar
Default Re: Which Precision Turbo?? (LEON)
1st post, cut me some slack!!! I run the SC60 (.63 a/r stage3 turbine, .60 a/r 60-1 comp side) on my GSR. Spool up time is pretty good and its a power rush from about 4500rpm and on!
Old Feb 13, 2003 | 07:46 AM
Smashback's Avatar
Default Re: Which Precision Turbo?? (dmecarboy)
Full boost by 3500 would be "pretty quick" IMO. 4500 might not be bad but it's not quick.
I admit I don't know a whole lot about picking the right turbo, but Art recommended the SC34 for what I want to do.
Too many people buy too big of a turbo I think. All they look at is the big HP numbers. It's kind of like putting a tunnel ram and dual 850 double pumpers on a street driven 302.
Old Feb 13, 2003 | 09:09 AM
LEON's Avatar
Default Re: Which Precision Turbo?? (Hatchblack)
I agree with you 100%.
I'm looking to replace my current turbo and am shooting for full boost at 3500rpms and about 280-320hp at 10-12psi. I'm thinking the SC50, SC32 or SC34, but not sure which one. Also, I'm not sure which A/R for the turbine. My car is street driven and I'm not after peak hp, but rather fattening up 'area under the curve'. I want power sooner. Right now i'm leaning towards the SC32 with .63 A/R. Any comments?
Old Feb 13, 2003 | 10:01 AM
Smashback's Avatar
Art was telling me the SC32 has a funky compressor map for some reason. Art? Art?
Old Feb 13, 2003 | 01:38 PM
He told me the same thing. Some thing about how the diameter of the inducer is different causes the map to wierd....
It would be great if Art could post the actual SC32 map!!!
Old Feb 13, 2003 | 07:00 PM
LEON's Avatar
What does 'weird' mean. What does the map look like? Where can we find the Precision turbo maps?
Old Feb 13, 2003 | 08:50 PM
95c1v1cs1's Avatar
If a turbo maxes out at say 450 hp. Is is most efficient up to that point or would it be more efficient at say 50-75 hp below that number? Or does it depend turbo to turbo?
Old Feb 13, 2003 | 10:17 PM
I was told that the HP # was it's rated crank capacity. However, they do underate the turbos HP capacity, so I would think it could handle at least 400WHP.
Old Feb 13, 2003 | 10:19 PM
Arturbo's Avatar
Better than steak
25 Year Member
you can see the maps at http://www.turboneticsinc.com . Since everyone one uses the same wheels you can kind of get an idea of how it might work.
Old Feb 13, 2003 | 10:52 PM
cool thanks Art!
Can you go a little indepth to why the SC32 map is "weird"...? And explain a little bit to what that means in terms of spool up, boost capability, efficency, so on.....? Basically, what makes it less desireable compared to the other SC turbos....?
Thank man!
Old Feb 14, 2003 | 06:13 AM
95c1v1cs1's Avatar
I've tried to learn a bit about compressor maps and from what people have said and what i think I think i know about compressor maps, the SC50 50 trim and the SC34 57 trim would be best for efficiency. Is it best to be at the top of the ovals or in the middle? And what do the curved lines going horizotally mean? Thanks for the posts. COrey
[Modified by 95c1v1cs1, 4:15 PM 2/14/2003]
Old Feb 28, 2003 | 03:48 PM
RyanAutry's Avatar
cool thanks Art!
Thank man!
I'm curious to hear what he has to say.
Old Feb 28, 2003 | 05:21 PM
boosted3g's Avatar
Default Re: Which Precision Turbo?? (RyanAutry)
I would call Rod at Precision. He is the coolest guy and will answer any questions honestly. I just ordered my TE64 today from them and i have dealt with Majestic for years.
Ckirk
18
Dec 14, 2018 10:33 AM
sjebo
Feb 21, 2016 08:27 AM
ctr32
Aug 6, 2009 10:50 AM
B20CR-X
Apr 6, 2006 08:38 PM
95c1v1cs1
Feb 10, 2003 06:04 PM
