Greddy Type-31 How much HP?
Old Feb 11, 2003 | 05:07 AM
420aNT's Avatar
Default Greddy Type-31 How much HP?
How much HP is the Greddy type-31 good for? I have one here that I had with my old setup and was wondering how much HP it can flow.
Old Feb 12, 2003 | 05:14 AM
420aNT's Avatar
Default Re: Greddy Type-31 How much HP? (18gTeg)
bump
Old Feb 17, 2003 | 07:36 AM
420aNT's Avatar
ttt
Old Feb 17, 2003 | 08:40 AM
420aNT's Avatar
Someone has to know this!!!
Old Feb 17, 2003 | 09:13 AM
SpdFrk's Avatar
Well the type 31 is a small intercooler and i would only use it for streets so i would say or guess 300-350whp.
Old Feb 17, 2003 | 09:44 AM
420aNT's Avatar
Default Re: Greddy Type-31 How much HP? (SpdFrk)
It's not really that small though compared to what some are running. I measured it and it is like 28" long 2.5inch Thick and 8inches tall.
Old Feb 17, 2003 | 10:07 AM
SpdFrk's Avatar
Is that 28" including the endtanks?
Old Feb 17, 2003 | 10:47 AM
420aNT's Avatar
I don't think so. I will have to check again. I think it was over 30" though with the endtanks.
Old Feb 17, 2003 | 04:26 PM
420aNT's Avatar
nobody
Old Feb 17, 2003 | 04:37 PM
Zero_son's Avatar
Intercoolers don't make power. I don't think there would be a limit if you set it up correctly either. Once again it depends on your set-up and tuning.
Old Feb 17, 2003 | 04:39 PM
420aNT's Avatar
Default Re: Greddy Type-31 How much HP? (Zero_son)
No your wrong there. Intercooler size does limit your HP potential. That like saying a 1.5" exhaust will make the same power as a 2.5" exhaust.
Old Feb 17, 2003 | 06:31 PM
SpdFrk's Avatar
No your wrong. There is a reason why there are such things as intercoolers whether it would be air to air or air to liquid coolers. If u put any sort of turbo kit on any car without a intercooler all its doing is blowing hot air into the motor and the motor doesn't really make good power. Also you cannot run really high boost even if u have a built motor or not. Eventually the motor is going to overheat or blowup.
As for the type 31 intercooler, a 28" intercooler without end tank is pretty big. I had no idea that it was that big. If that where the case then i would say that it is good for 500+whp. But if u have the option why not just be on the safe side and get the type24. IF u are planning to make crazy power.
[Modified by SpdFrk, 3:33 AM 2/18/2003]
Old Feb 18, 2003 | 05:08 PM
420aNT's Avatar
I just measured it again. It is 27 for the core and 32 from endtank to endtank. The height is 7.75 and the thickness is 2.75
Old Feb 18, 2003 | 06:26 PM
420aNT's Avatar
someone has to have some kind of idea
Old Feb 18, 2003 | 06:53 PM
SleeperCivicEX's Avatar
From what I've noticed in my car, after bolting on the FMIC I probably experienced a 15-25HP increase at 7-8psi just by cooling the air. Thank you very much....
Old Feb 18, 2003 | 06:57 PM
DeepSi's Avatar
Default Re: Greddy Type-31 How much HP? (SleeperCivicEX)
ok, i think i have your answer....
the type-31 starts losing efficency at 18-20psi. As for how much HP, you cannot really put a HP number down, as different cars make different HP numbers, but the intercooler efficency rate is based upon pressure. hope that clarifies this dispute.
-deepsi
Old Feb 19, 2003 | 12:41 AM
Midwestrider's Avatar
Have you tried calling Greddy themselves?
Old Feb 19, 2003 | 07:26 AM
swrdply400mrelay's Avatar
How is your intercooler so long?
http://www.nipponpower.com/forced_in...tercooler.html
Intercooler core sizes (mm):
Type 18: H266 x L410 x W85
Type 23: H294 x L600 x W115
Type 24: H276 x L600 x W76
Type 25: H294 x L600 x W149
Type 26: H132 x L410 x W85
Type 31: H186 x L600 x W76
Type 32: H258 x L600 x W115
Old Feb 19, 2003 | 03:49 PM
420aNT's Avatar
Default Re: Greddy Type-31 How much HP? (swrdply400mrelay)
Thats what it measures with my tape measure.
mark11017
Apr 20, 2011 06:47 AM
kuja396
Mar 8, 2008 07:08 PM
JDM turbo DC
Aug 11, 2006 08:13 AM
ladyjetspeed
Oct 9, 2005 03:04 AM
HaRrYbOy
May 3, 2004 02:27 PM
