r
Old Feb 13, 2003 | 05:46 PM
93H22ACX's Avatar
Default r
When you guys first turbocharged your cars, did it pull hard? Or did you have to do some tunning before you actually felt satisfied? I know you have to tune it, but, shouldn't it be stronger?
I feel like my car feels a little stronger if not the same as N/A...any help/suggestions?
Thank you!
oh by the way....the fuel and ignition stuff i have for my setup is an inline fuel pump, Vortech FMU 12:1, and a MSD 6BTM set at .50
Old Feb 13, 2003 | 05:59 PM
I Like Boost's Avatar
Default Re: r (jz)
ok if you cant feel the difference there is really some wrong. it's a day and night difference get that **** fixed.
Disco Stu's Avatar
Default Re: r (jz)
Is your prelude black? Lowered down on stock wheels? Thats the only boosted prelude I've seen around here.
Old Feb 13, 2003 | 06:00 PM
swrdply400mrelay's Avatar
Default Re: r (95PRELUDEVTEC206)
Thank you!
I got that same feeling as you. Everyone else that rode in my car said it was definitely faster though. So my conclusion is that I just have a speed insensitivity issue. The only way to cure this, is to be ridiculously faster than you thought you were going to need.
But that aside, did you dyno your car? Is your clutch stock?
Old Feb 13, 2003 | 06:02 PM
93H22ACX's Avatar
Default Re: r (jz)
Thanks for the reply....
my turbo is a T3/T04B .63 Super V Stage 3 Wheel 54.....Its a drag kit for my H22 and the turbo is rated at 450hp. My fuel setup is a Vortech FMU 12:1, Inline Fuel Pump, and stock H22 injectors (320cc).... I also have a BTM set at .45-.5 degrees of retard per PSI.
I dont konw why but it doesnt pull hard. I know all the hardware is installed correctly. My compression test yeilded pretty good numbers.....+15/-15 per cylinder......
It was running 7-8psi. Didn't pull hard so I boosted 9-10psi and still felt the same. My autometer A/F gauge is all the way green and my apexi turbo timer is 10:1 A/F
Old Feb 13, 2003 | 06:04 PM
93H22ACX's Avatar
no its not a stock clutch...ACT Heavy Duty...it feels like nothing compared to my nitrous setup of 70 shot that i used to have. and everyone that drove my car says it feels kind of the same..... Here is a story....I raced my cousin's GSR on the freeway. NA I can pull about 1.5 cars....Now i'm boosted at 7psi and I can only pull the same about 1.5 cars.....
My prelude is a greenish blue with Wings west RS kit.
No i havent dynoed it yet
[Modified by 95PRELUDEVTEC206, 3:06 AM 2/14/2003]
Old Feb 13, 2003 | 09:59 PM
93H22ACX's Avatar
Default Re: r (IMPULSE B18C-T)
[q]ok if you cant feel the difference there is really some wrong. it's a day and night difference get that **** fixed.[/q]
do what besides tuning it
Old Feb 14, 2003 | 12:56 AM
MiraiZ's Avatar
10:1 a/f a bit too rich? try leaning it out a bit, your probably drowning your engine...
Old Feb 14, 2003 | 04:43 AM
symba's Avatar
Default Re: r (MiraiZ)
Yeah, but how accurate is the APEXi Turbo Timer at reading A/F? I think it does need more tuning.
Old Feb 14, 2003 | 06:49 AM
93H22ACX's Avatar
Default Re: r (symba)
does it really rob that much power if its too rich? I mean robbing the power to the extent of it being similar to NA?
Thanks
Old Feb 14, 2003 | 07:17 AM
b16ahybrid's Avatar
Thanks
Actually yes, i'm being robbed of about 40whp rite now because i'm runing way to rich (10.0:1+) runing too rich has the same effect as runing to lean (power wise)....your basically flooding your engine..
check all of your connections, something may be loose. You should feel a big difference esp at 10psi........it may also be your air/fuel ratio...10:1 is like dumping fuel via hose
Old Feb 14, 2003 | 07:20 AM
93H22ACX's Avatar
Default Re: r (b16ahybrid)
everything seems goood.....at idle my vacuum reads 22 inch steady.....when i boost it reads 8 psi steady.....but not really any power....
although it makes a throtty sound when boost kicks in.....kind of like a loud exhaust leak......also i dont know if its the filter or what but when i had rev the throttle there is a little poping noise from the turbine.
Old Feb 14, 2003 | 07:57 AM
MiraiZ's Avatar
again...running rich....try leaning out, and you won't back fire...also check your spark plugs...they're probably black as constipated ****! What fuel solution are you using?
Old Feb 14, 2003 | 10:04 AM
93H22ACX's Avatar
I am using Denzo 2 step colder...I believe Denzo 26.....they are gapped at .034 I checked them and they looked fine. Kind of cocoa colored with some black carbon build up on the first 2-3 threads....
I am using 92 Octane always That is the highest here
Old Feb 14, 2003 | 06:55 PM
CzanSOHC's Avatar
try only retarding .25 per psi w/ the btm. Also is your car holding boost fine? you might have to large of a turbo which at onl;y 7psi is not in it's effective range...just a thought...
Old Feb 14, 2003 | 07:02 PM
93H22ACX's Avatar
Default Re: r (CzanSOHC)
I think so too....i think 12-14psi. Its a T3T04B Super V1/V2.....25 per PSI even when you go higher boost? or just up to 8psi and above that is .45
[Modified by 95PRELUDEVTEC206, 4:03 AM 2/15/2003]
b16a4
Jan 14, 2007 10:41 AM
radioren
Apr 8, 2005 02:19 PM
omrigaron
Jun 22, 2004 03:20 PM
superduperman
Aug 7, 2003 10:25 PM
turbogsr13z
Apr 13, 2002 06:19 PM
