how to install inline fuel pump
Old Feb 11, 2003 | 04:26 PM
ridnmyhonda's Avatar
Default how to install inline fuel pump
i have an inline fuel pump it says max psi 125? and i have no clue how to install it, i know i splice into a hose but i which hose is it? thanks
Old Feb 11, 2003 | 04:43 PM
flat-blk-HB's Avatar
Default Re: how to install inline fuel pump (ridnmyhonda)
I beileve you can put it between the fuel filter and the the rail. Cut the hose and clamp it to the inline between the 2.
Old Feb 11, 2003 | 06:34 PM
Default Re: how to install inline fuel pump (flat-blk-HB)
there is a hose that goes from the firewall then into fmu and then out of the fmu into the fuel filter. so which hose is it?
Old Feb 11, 2003 | 10:25 PM
gtcali's Avatar
Neither, its the on the other side of the fuel rail.
The FMU is hooked up the the return line.
Old Feb 11, 2003 | 10:34 PM
Sleepin''s Avatar
You want the other side. Should be the passenger side of your car. The line that goes from the fuel filter to the fuel rail. It has a Banjo fitting going into the fuel filter. Splice the fuel pump into there. Make sure all your connections are tight because fuel leaks suck.
[edit]: make sure to leave yourself enough hose to mount the pump to the firewall.
[Modified by Sleepin', 2:35 AM 2/12/2003]
EVOCELICA
Oct 12, 2003 11:05 AM
superduperman
Jun 26, 2003 08:52 PM
v88dx
Feb 2, 2003 10:36 AM
ludelvr
Mar 26, 2002 07:57 PM
