why nitrous good with high compression ??
Old Feb 11, 2003 | 09:57 PM
Cyber ITR's Avatar
Default why nitrous good with high compression ??
just wondering because usually with turbo we lower the compression so we can higher boost
so why nitrous works better with high compression ?
Old Feb 11, 2003 | 10:06 PM
highbrid's Avatar
Default Re: why nitrous good with high compression ?? (VTEC_SiR)
basically its because more compression will yeild more hp. Even running higher compression on turbo will yeild more hp than the same amount of boost with lower compression. People just lower the compression on turbo motors to increase safety, and generally you can run more boost then with the lower compression. It all depends on how much tuning you do. In theory you could run as much compression as you want with turbo or nitrous, or both, as long as its tuned well.
Old Feb 12, 2003 | 04:22 AM
PM-Performance's Avatar
Default Re: why nitrous good with high compression ?? (highbrid)
couldnt have said it better myself.
Old Feb 18, 2003 | 07:33 PM
EVOCELICA's Avatar
New User
Default Re: why nitrous good with high compression ?? (DR DOOM)
nitrous runs well with high compression due to it's cooling of the intake charge
Old Feb 18, 2003 | 07:37 PM
laughinxxx's Avatar
New User
You can also run fuel cells with race gas and only supply your fuel rail with the top shelf fuel when you are spraying. Also, nobody would ever drop their compression to run alot of nitrous on a street car. Instead we keep or raise the cr from stock and knock the timing back until it quits detonating.
twizt2
Dec 24, 2002 08:28 PM
UTI tunin
Sep 25, 2002 12:52 PM
baonest
May 7, 2002 10:31 PM
dontcare61776
Apr 7, 2002 09:27 AM
charjacq
Dec 12, 2001 03:35 PM
