Can hondata OBD 0 with pr3/pwo run a SOHC
Hey, i bout a hondata stage 4b from a friend.. i wanted to know if i can run a sohc non vtec turbo setup with it.. i dont know what will happen for vtec and a few other sensor.. converting to obd1 is a lot of money at this point.. i will need like 4 things.. ecu , coversion harness, distrubtor, and o2 sensor..? right...
So.. I need to know what should be my next step.. should i buy a pr3/pwo.. or should i wait it all out and get a p28... i would love to make the obd 0 work.. just want to know if it is going to run like it should.. on a hondata..?...
[Modified by havok hybrid, 8:02 AM 2/13/2003]
Re: Can hondata OBD 0 with pr3/pwo run a SOHC (ricodemus)
the hondata i have... can be ran in a p28 or a pwo pr pr3. Im going to try to run it on a pr3.. sohc turbo ..
Re: Can hondata OBD 0 with pr3/pwo run a SOHC (havok hybrid)
You may be able to do this, but will have to run on the low cam only and to keep from going into limp mode you will have to put some kind of a resistor in place of the vtec pressure and vtec spool so it's happy and thinks you have vtec.
In other words, it will be better for you to convert the car to OBD1 and use a p06, p74 or p75.
[Modified by Spunkster, 4:18 PM 2/13/2003]
Prelude91siT
07-06-2004 12:17 PM
