yes! my fuel system is almost complete!
Old Feb 12, 2003 | 09:14 PM
accordfreak's Avatar
Default yes! my fuel system is almost complete!
after gathering parts for my fuel system i almost have it ready:
hondata
550cc
paxton fpr
SS lines
aem rail
just thought i'd share just cuz accord owners are rare in the FI board...
and of course H-T helped me spend money like crazy heheh
oh and I just made this pressure tester cuz i gotta find where i'm leaking boost...
edit: spelling
[Modified by accordfreak, 6:14 AM 2/13/2003]
Old Feb 12, 2003 | 09:28 PM
rOby's Avatar
Default Re: yes! my fuel system is almost complete! (accordfreak)
looks nice...pioneer inovater on that pressure testor hehe
Old Feb 12, 2003 | 09:35 PM
BoostedSi's Avatar
SHouldnt the regulator be connected to the other side of the fuel rail??? and the side you have it connected go to the fuel filter?
Old Feb 12, 2003 | 09:41 PM
rOby's Avatar
Default Re: yes! my fuel system is almost complete! (BoostedSi)
its reversible as long as the feed n returns go along w/ the way he has it
Old Feb 12, 2003 | 09:46 PM
GZERO's Avatar
nice to see accord people around here
Old Feb 12, 2003 | 09:52 PM
Default Re: yes! my fuel system is almost complete! (GZERO)
thanks for your comments. yeah accords are the other way around... my stock fuel filter is on the driver side..
now a question i forgot to post earlier....
my RC 550cc injectors doesn't fit into the AEM rail... i even tried putting on the stock ones but they seem to not budge into the rail.. i tried to screw it down with the rail and injectors in place but the O-rings ended up ripping (stock injectors). i took off the orings on the stock injectors and of course it fits fine... so...
Do I need new o-rings?? or do i have to bored out the aem fuel rail holes ????
btw the RC injectors fit fine on the stock fuel rail.....
Old Feb 12, 2003 | 11:16 PM
LiLOtaku's Avatar
do the paxton fpr's come with the guage? and is that a liquid filled type guage? looks good mang .
Old Feb 12, 2003 | 11:19 PM
rOby's Avatar
Default Re: yes! my fuel system is almost complete! (LiLOtaku)
you'd probably need to get the holes on the rails machined or drilled out to fit the top of the injectors..any machine shop cn do it or u can too.
roby
Old Feb 13, 2003 | 01:12 AM
Kwuaymaikrup's Avatar
Default Re: yes! my fuel system is almost complete! (rOby)
Had the same problem with my RC 550's and AEM rail. Just use some lube of somesort and lightly apply it to the o-rings. It was a tight fit but it worked.
Good luck.
Ryan
Old Feb 13, 2003 | 01:23 AM
boostaholic's Avatar
Those RC's should fit fine in the AEM rail with stock orings. Make sure you put a little motor oil on them before putting them into the rail. Makes them go in a lot easier.
Old Feb 13, 2003 | 07:26 AM
Johnyquest's Avatar
Default Re: yes! my fuel system is almost complete! (boostaholic)
yeah they always fit tight, a little bit of vasaline or somthing of the sort works wonders. Just lube the rings up nice, and twist em in, being careful to put them in straight...
It's supposed to be tight!
Old Feb 13, 2003 | 01:02 PM
Default Re: yes! my fuel system is almost complete! (Johnyquest)
thanks for your help guys.. i'll try putting oil on them and see how that works
LiLOtaku- thanks! yes it is a liquid filled gauge..and it was bought seperately. i've heard on a few occasions here that non liquid filled break due to the vibration...
[Modified by accordfreak, 10:55 PM 2/13/2003]
Old Feb 13, 2003 | 01:53 PM
poid's Avatar
Just wondering, is the new fuel rail really needed or is the stock one good enough?
Also what kind of fuel pump are you using dude?
Nice setup BTW
Old Feb 13, 2003 | 01:58 PM
Default Re: yes! my fuel system is almost complete! (poid)
Nice setup BTW
thanks i've read here that stock one is good enough up to 350 hp? somewhere around there... but i decided to get the AEM rail because some guy was selling it for 50 dollars.. it's also easier for me to get the correct fittings and such.. plus it looks nice heheh
i'm going to be using the walbro 255lph pump
Old Feb 13, 2003 | 02:03 PM
poid's Avatar
damn quick reply!!
Thanks for that, in that case the stock one will do me fine. The walbro pumps can be had for reasonably cheap comparatively i think, been looking at Bosch pumps so far and they seem to be a bit more.
When you get that thing tuned and running be sure to post up some numbers, i'm always interested to see what accords can do
gappy4444
Honda Civic (2006 - 2015)
12
Sep 15, 2012 10:04 PM
k24egturbo
Oct 19, 2010 08:41 PM
Bantam
Mar 7, 2003 08:58 AM
BoostedH23a1
Feb 10, 2003 11:54 AM
